Finally picked up a 931 bellhousing.
IMG_20150717_210930296 by
Vex Art, on Flickr
Sadly, it looks like the 931 bellhousing, despite being used on an Audi I4 has the I5 bellhousing pattern (along with sharing the lower 2 944 bellhousing botls). This doesn't really help since the 07K uses the VW I4 pattern. They only have 1 bolt in common.
931 pattern bolts up perfectly to the 'vintage' I5.
IMG_20150718_200259661 by
Vex Art, on Flickr
01E bellhousing (modified to fit 07K; two bolt holes at the top need trimmed off) on top of the 944 bellhousing. Red are the VW I4/07K bolts, black are the vintage I5 bolts. The lower 944 bellhousing bolts share the vintage I5 bolts. A large portion of the upper 944 bellhousing would need to be removed. Two of the 07K bolts could possibly be added to the 944 bellhousing by drilling holes and/or adding welding on a small amount of material to the bellhousing.
IMG_20150718_231906658 by
Vex Art, on Flickr
The 01E bellhousing template mounted on the 07K engine. The red shows the 07K bolts, and yellow shows the 931/I5 bolts. Only one bolt is shared.
IMG_20150718_205425310 by
Vex Art, on Flickr
I think it would be possible to add at least two more shared bolts to the 931 bellhousing pretty easily. The 07K red hole could easily be drilled, there is a nice flat spot on the bellhousing for it.
IMG_20150718_231546048 by
Vex Art, on Flickr
The other one would require a small tab to be welded to the 931 bellhousing. This would give 3 matching bolts. I'd want to find at least one more.
IMG_20150718_231558430 by
Vex Art, on Flickr
One ear on the 931 bellhousing would need to be removed (much like the 01E) to clear the 07K timing chain cover. But not nearly as much material as the 944 bellhousing would need.
I'm going to order an OEM 01E spacer to help do some more planning. I think both the 944 and 931 bellhousing would take the same amount of work to make work with the 07K. The 944 would require a lot more trimming and then welding to 're-enclose' the bellhousing. The 931 would require slight modifications and no welding to 're-enclose'. An adapter plate might be the best route and would probably work better with the 931 bellhousing. I need to get an 07K clutch/flywheel so I can figure out stack heights and see if I can even run a spacer/adapter plate.
Progress will continue to be slow, the 968 is at the bottom of the list of many projects...
Odd Cylinders YouTube Page1992 Porsche 968 (07K transplant in progress)
