B3 044 pump install
B3 044 pump install
I have been looking for a while now, and obviously not in the right spots. Can anyone point me in the right direction for the fittings I will need to install the 044 pump in the factory location on my 91 80Q? Thanks.
Re: B3 044 pump install
Are you going to run a -6 fuel line too or use stock?
I would like to keep the stock line for now. The pump came with a -6 adaptor, but not ready to run a whole new line right now.
Can I use the fittings from the factory pump? Sorry for the dumb questions, but I don't have the car close to me, and would like to order any fittings I will need. Thanks
I think the output fittings are the same. Use the check valve and banjo fittings. For the inlet, get a -8 barbed fitting.
Ok, so a M18 with a 1/2" Barb? Sounds easy enough.
Like this one?
http://www.ebay.com/itm/like/2914392504 ... ps&lpid=82
Like this one?
