Audi I5 Crank Cogs
Audi I5 Crank Cogs
Postby loxxrider » Sun Aug 09, 2015 12:32 pm
**Work-in-progress**
This thread is intended to be a one-stop-shop for everything you've ever wanted to know about Audi I5 crankshaft cogs. Also known as crank sprocket, pulley, gear, etc.
It is well-known and documented that when doing a timing belt job on an Audi ur5pot, whether that be AAN, 3B, ADU, ABY, 7A, etc. the crankshaft cog must be replaced with a new one because the stock gear is made of sintered steel. Sintered means the material (in powdered form) is put under tremendous force and heat such that the material fuses together. This creates a part with questionable strength properties, especially when exposed to impulse loads. Using one of these stock cogs is perfectly fine when installed properly, but they should should be replaced with every timing belt service and using an impact driver to install them, without a crankshaft locking device at least, is NEVER a good idea.
Instead of buying a new one every time the timing belt is changed, why not just make a much stronger version? Well, several have done this. However, the information about these high-strength cogs is not readily-available or so far spread out that it'd be nice to be able to take a look at it all in one place. Also, when you do have the information in-hand, how do you choose which one to use? That's exactly what this thread is for!
What is available?
- Stock
- Tommi’s Billet
- CWG Racing (Chris’ Billet? :D) *not in production due to defect in hole spacing*
- Dahlback Racing
- Terrybullwon from S2 Forum 2 Piece(Jeff Gerner Recommended – separate belt guard)
- SPM?
- Volcano RS from S2 Forum 2 Piece (separate Key)
- 034 Motorsport (single piece?)
- Faheemo from S2 Forum 1 Piece
- Audi * line (eBay.de user)
- PKM
Stock
Material: Sintered Steel
Construction: Single piece
Tooth Profile: Stock - exact
Price ~$85 on average
Availability: Order anywhere you normally get your parts. Still readily available.
Advantages: Cheap and guaranteed to work perfectly when installed correctly.
Disadvantages: Made of sintered metal which makes it prone to cracking. One time use for safety.
Stock cog with belt wrap. Notice the cracks! :shame:
Tommi's Billet
Material: Steel (???)
Construction: 3 piece (separate dimple and separate key)
Tooth Profile: Squared-off teeth, correct valleys?
Price $180
Availability: Readily available at [url]EFIexpress.com[/url], Tommi's Billet website, and more
Disadvantages: At least one user has reported that the teeth of the gear are not timed correctly with the clocking of the holes for alignment with the crank pulley. This makes setting timing and adjusting belt tension nearly impossible with a stock cam pulley. Also, the teeth are not rounded at the top like the supertorque belts are made for. This could cause premature wear on the belt. Look very closely and you will see that the edges of the teeth are angled rather than rounded. Don't let the curved front face of the gear fool you into thinking they have a curved profile.
Stock vs SPM vs Tommi's Billet
Illustration of tooth alignment problem on the Tommi's Billet
CWG Racing
Material: Heat treated 4340 steel
Tooth Profile: Stock teeth tops (rounded), rounded valleys
Price: $200 plus shipping. Could go lower in quantity.
Availability: I could have more made if anyone wanted some, but I think there is a better option.
Advantages: Among the strongest of all gears using heat treated 4340 steel. Ground inside diameter to ensure perfect fit onto crankshaft. Top tooth profile is exactly the same as stock, rounded “super torque” style teeth. Machined dimple for crank pulley alignment. Can be made more cheaply than most of the other gears here because of the milled teeth (rather than cut by gear), although testing still needs to be done on this tooth design with respect to long term reliability and power-holding potential.
Disadvantages: *FAIL GEAR* These were made with the bolt holes for the crank damper in the wrong place due to manufacturer mistake. Production has ended since. No plans to continue production because it isn't easy to compete with the Terrybullwon gear! Valleys of teeth are rounded in order to keep cost down and allow the gear teeth to be produced by milling rather than by grinding with a special-made gear cutter or by wire EDM (both processes would generally require the gear to be made in two pieces). Whether this is a disadvantage or not is questionable. I will test this gear out on my avant for stock, long-term reliability, and may also test it on the revver if I have the balls :lol:
CWG Racing vs stock
CWG Racing modified for dry sump use - with belt wrap
Tooth valley profile vs stock (valley is pointing up) stock is dotted trapezoid, CWG racing valley is the solid line
Dahlback Racing
Material: Steel (??)
Construction: 3 piece (separate key and alignment pin)
Tooth Profile: Possibly squared-off teeth
Price $345 shipped from Dahlback
Availability: Currently available from [url]Dahlbackracing.se[/url]
Advantages: According to fcarspec1 on quattroworld, it uses a separate key that slides a little deeper into the crank notch than the stock key.
Disadvantages Also according to fcarspec1, you have to do a wire transfer to their bank. Part# DBR.Z26.D64.8.CD5 and also the key is not quite in the same place as the OE part so the mark on the damper is off a little once installed, so you must time the engine with the mark on the flywheel. Teeth appear to be squared off just like the Tommi's Billet gear. This all sounds very similar to the Tommi's billet gear... :idunno:
Material: EN24 Steel
Construction: 3 piece (separate belt guard and pin, but integral key)
Tooth Profile: Same as stock (confirmed by Jeff Gerner)
Price $155 plus shipping from UK
Availability: Currently available from Terrybullwon http://www.s2forum.com/forum/showthread.php?t=66425
Advantages: Recommended by Jeff Gerner as the crank cog of choice due to it's build quality and especially the gear profile which matches the stock "super torque" (rounded edges on teeth rather than squared off) tooth profile. Valleys are same as stock as well. Also coated for corrosion resistance. Made by HPC gears, most likely the biggest and best gear cutters in the UK
Disadvantages: ??
Terrybullwon gear
Here you can see the separate belt guard which is pressed on
Belt wrap
SPM?
Construction: ??
Tooth Profile: ??
Price ??
Advantages: ??
Disadvantages: Possibly not available. I have only seen one in this picture. Tooth design looks like it could be "off."
SPM in the middle apparently
Material: Steel (???) Heat treated
Tooth Profile: Possibly rounded teeth and has rounded valley
Price ~$108.50 plus postage from the UK
Availability: Last post on thread was in 2013. Not sure if still available http://www.s2forum.com/forum/showthread.php?t=33219
Advantages: Cheap!Comes in wider width as well for using 25 mm belt. Appears to have correct, rounded teeth.
Disadvantages: Possibly NLA
Volcano RS cog 25 mm vs stock width
Belt wrap
034 Motorsport
Material: "High strength chromoly"
Construction: Appears to be 3 piece (separate key and alignment pin)
Tooth Profile: Appears to have squared-off teeth
Price $204
Availability: Order from 034 http://store.034motorsport.com/crank-pulley-cog-high-strength-chromoly-audi-i5-super-torque.html
Advantages: ??
Disadvantages: Teeth appear to be squared off and not the "super torque" style even though it is advertised as such. I could be wrong though. If so, belt wear will be accelerated.
Material: EN19T tool steel. Some (not all) heat treated and have corrosion-resistant coating. It seems that all the latest ones were coated at least.
Construction: Two piece? (undercut integral key and separate alignment pin)
Tooth Profile: Teeth cut on a gear-cutting machine. Not sure if super-torque style tooth edges or not
Price $225
Availability: http://www.s2forum.com/forum/showthread.php?t=32516 It seems they may not be made anymore.
Advantages: This is the gear EFIexpress use to sell. It was of good quality. The only questionable thing is the teeth, but they haven't seemed to cause any problems.
Disadvantages: No longer in production?? Appears to have sharp, squared-off edges on teeth rather than rounded.
Faheemo from S2 Forum cog
audi * line (eBay.de user)
Material: C45 steel
Construction: 4 piece (separate key, alignment pin, and belt guard)
Tooth Profile: Appears to be very good. As close to stock as the Terrybullwon gear from the looks of it
Price 148 euro (approx) $163 US without shipping. Shipping is likely more than 20 euros
Availability: eBay.de username audi * line - located in Poland - may or may not ship to US. Contact seller
Advantages: Appears to have very nice teeth in the correct profile. Seems to be well made by an experienced machinist judging from pictures.
Disadvantages: Seller may or may not ship to US.
PKM
Material: ???
Construction: Appears to be very similar to Terrybullwon's gear but with separate key and rolled sheet metal pin (not a fan of these two things)
Price ~220-230 euros
Availability: Autewo.de (and eBay)
Disadvantages: The separate key and rolled sheet metal pin are... cheap. It may be perfectly functional, but I prefer integral pieces and precision machining. It makes you question the quality of the rest of the gear.
Re: Audi I5 Crank Cogs
Postby yodasfro » Sun Aug 09, 2015 8:56 pm
yodasfro
Postby loxxrider » Sun Aug 09, 2015 9:19 pm
Oh nice! That one appears to have all the right elements. The only thing I don't like about it is the separate key, but that's just me. Nothing wrong with it, I just like the integral key better.
I will add it to the list!
Postby 85oceanic » Sun Aug 30, 2015 9:08 pm
Thank you Chris! Awesome and informative info!
Postby themagellan » Wed Sep 02, 2015 5:38 pm
Wow! THANK YOU! I love you man.
Postby popdemonic » Thu Sep 03, 2015 12:56 am
Thanks Chris.very informative stuffs.
popdemonic
Postby loxxrider » Thu Sep 03, 2015 5:29 am
Happy to help!
Postby Terrybullwon » Thu Oct 01, 2015 5:05 pm
loxxrider wrote:**Work-in-progress**
Availability: Currently available. Jeff should have them (contact at [url]fourringperformance.com[/url]) and also from Terrybullwon
Thanks for the write up i only sent Issam two over for him and Jeff for there motors, so no one other than my self has stock of these pulleys at the moment. The Price is lower than some my mark up is not massive i do it more for the love. I am working on a adjustable gear and this will be available late fall i hope.
A really nice bit of kit this will be i am pretty excited to get mine on my motor!
Thanks James
Terrybullwon
Postby loxxrider » Tue Oct 06, 2015 1:10 pm
James, I have updated the information to reflect that the gear should be bought from you. Very cool that you're making an adjustable version. I will add it when you have finished it!
Also added another option from PKM.
Postby gabriel.b » Fri Oct 16, 2015 8:06 am
I just bought one from 034 and they actually sent me a Tommis. I think that means they no longer make their own?
gabriel.b
Postby Wheeljack » Fri Oct 16, 2015 9:35 am
James (terrybullwon) has them available and ready to ship (at least as of a few weeks ago). Cheaper than 034's including shipping from the UK. And arguably the best design out there.
http://brydon-eng.com
Wheeljack
Postby k2exoman » Sun Nov 01, 2015 11:29 am
Thanks for compiling all of this information loxxrider.
I've reached out to James (terrybullwon) directly.
k2exoman
Postby Noisy Cricket » Sun Nov 01, 2015 2:56 pm
Is it really that big of a problem? The crank cog on my JT has been on and off several times with an impact gun and that was 100k+ ago... odometer reads close to 380k now.
Maybe it is just people using really weak crappy guns from Sears or Harbor Freight with only 100psi air pressure from their little pancake air compressors and the gun sits there rattling and rattling and rattling instead of just ZIP off and on?
Or is it more of a problem with being insufficiently tight because people aren't checking the torque with a torque wrench, and the harmonic damper bolts to the crank cog, and long crankshafts in high power engines make a lot of torsional vibrations working that critical junction loose. Look at the other end of the crank... eight 10mm bolts to hold the flywheel in place, and you know that isn't for the torque because the driveshaft is held on by six spindly 8mm bolts and there is torque multiplication before you get to that point.
Pete, that rallycross guy
'06 Volvo S60 R (Swedish GTR)
Noisy Cricket
Postby audifreakjim » Wed Nov 04, 2015 5:44 pm
I have long suspected the pulley itself being out of balance causing all kinds of problems. For example, I zero balanced my old 034 pulley along with the rest of the motor, with the trigger wheel welded to it, and it seems to be the only specimen to have lasted past a couple thousand miles. It's probably 30-40k and still going. I always wonder if the crank cog failures. are related to small vibrations.
Postby Terrybullwon » Fri Nov 27, 2015 6:37 pm
k2exoman wrote:Thanks for compiling all of this information loxxrider.
Yep Thanks k2exoman your pulley was sent and should be with you in the next week or so.
Terrybullwon
Postby FRP » Mon Nov 30, 2015 10:44 pm
Nice fair and objective compare. Good job!
FRP
Postby 88a5tq » Mon Aug 15, 2016 7:43 pm
Call me a curious Cassandra but would 11 ft-lbs be considered an acceptable torque for those 4 little guys securing these cogs? My Bentley walked off :huh:
Janitor at large
$500 butt-hurter
88a5tq
Postby audifreakjim » Mon Aug 15, 2016 11:27 pm
20 Nm (15 ft lb)
Postby 88a5tq » Wed Aug 17, 2016 8:49 pm
:ty:
Janitor at large
$500 butt-hurter
88a5tq
Postby blackghost » Wed Sep 06, 2017 10:36 am
I've purchased two gears from James -Terrybullwon. TOP NOTCH! I also had an issue with shipping, and James resolved it quickly! Thank you very much!!
blackghost
Postby 88a5tq » Wed Sep 06, 2017 3:30 pm
I bought mine (terrybullwon) second hand, however still brand new. I was blown away by it's quality :D
Janitor at large
$500 butt-hurter
88a5tq
Postby Foscora » Sat Oct 28, 2017 4:54 am
Hey guys, sorry I had to bump this thread, I wondered if any of you recalls of a guy on a forum or a company making crank gears for 10V engines ( part 035105263C ) ?
I'm 100% sure I saw it while wandering on a forum but I can't remember where / couldn't find it ...
In case anyone can help I'd be thankful ;)
Foscora
Postby Terrybullwon » Tue Nov 27, 2018 5:15 pm
Guys just a heads up another batch of the "terrybullwon" pulley will be ready in a few weeks and i am running a pre production price to soften a massive out lay. Please contact me with interest at James@jmdmotorsport.com
Terrybullwon
Postby Terrybullwon » Mon Apr 13, 2020 11:04 am
Again we are running a group buy on 100 of these pulleys please get in touch either via the S2 forum or via email. Price and details are on the S2 forum.
Kind regards James Stay safe!
Terrybullwon
Return to General
Users browsing this forum: No registered users and 8 guests
