VEMS no spark while cranking with low voltage
Postby chaloux » Wed Jul 12, 2017 10:44 pm
So Ross, the current owner of 4FOXSN8X, is having an issue where when he or the mechanic goes to start the car it won't start. He has some small parasitic draw that is lowering battery voltage past 12v and then he's getting no spark. Does VEMS stop sending spark after a certain voltage point? Can that be disabled?
Thanks dudes. I can't find anything online, or at least on my phone, that talks about this but I vaguely remember it being a thing.
Yes... I know a charger for ten minutes or a battery tender would "fix" the low voltage until the draw was found.
DEAD :( - 1996 S6 mit TDI
Re: VEMS no spark while cranking with low voltage
Postby ringbearer » Wed Jul 12, 2017 11:36 pm
I don't know but you are a great car seller, still helping years later :)
Postby chaloux » Thu Jul 13, 2017 6:08 pm
The answer is that NO this doesn't exist. Thumbs up.
Postby carl » Fri Jul 14, 2017 4:40 pm
Won't spark or losing trigger signal?
carl
Postby 88a5tq » Fri Jul 21, 2017 8:10 am
Any chance you related the starter signal wire? I had this happen and it was the signal wire I ran that rubbed through on the axle and shorting out!
Janitor at large
$500 butt-hurter
88a5tq
cron
