What did you do to your car today?
scubagli
Post by scubagli »
I couldn't find a thread like this here, if there is one please let me know. Just a place for non project car stuff. Anyway I did this yesterday.
From that to this.
Re: What did you do to your car today?
Dip?
Not a damn thing. :( Saving for a fuel pump and other goodies.
scubagli
Post by scubagli »
chaloux wrote:Dip?
Yes, for some reason tapatalk inverted the images, the blue is the new color.
All_Euro
Post by All_Euro »
scubagli wrote:
chaloux wrote:Dip?
That's pretty cool - how did it turn out compared to something like a vinyl wrap? All in one day too so prep and application must be pretty quick.
Work - Houzz / linkedin
Play - Haldex Swap
scubagli
Post by scubagli »
It turned out ok, I'm going to peel it and redo it, made some mistakes and also knocked over a gallon of color so it's spotty in areas.
scubagli
Post by scubagli »
New new blue.
Took my dad for a ride for the first time in the 200 which he hadn't seen since I picked it up and took him for a ride with it chipped 8 years ago.
He giggled. Worth it.
UrSobsessed
Post by UrSobsessed »
Stared at it.
scubagli
Post by scubagli »
Scraped off old reg, stuck new one on, ordered thermostat and valve cover for the a4, also pass tierod end and pass strut bearing for the v8. Also picked up an abt ecu for the v8 can't wait to get it...
Found both front caliper carriers on the cabriolet had 1 seized slide pin each. That explains the brakes sucking. Proceeded to remove one seized pin but broke off the other...
Off to the junkyard today.
scubagli
Post by scubagli »
Put the chipped ecu in the V8 today. It feels faster.
Replaced my IAC sensor, and put on a real weather pack pigtail. Works well again.
Wilford Brimley
Post by Wilford Brimley »
walked out in the garage. Looked at the car for about 30 seconds, grabbed some tools, and went to work on the GF's E30
A20V200
Post by A20V200 »
Polished my SS Stebro muffler and tips….man was it durty!!!
scubagli
Post by scubagli »
Put a thermostat in my b6, I thought an mkIV Gti was a pain....also removed rear muffler on the v8, sounds pretty good, it will do until I can build an exhaust.
