3b FPR and line
uberaudi
3b FPR and line
Post by uberaudi »
While driving around today I started to vaguely smell gas. I pulled over and checked and didn't see anything but after I pulled into the garage, under closer inspection, I saw the culprit. Its the braided line going from the FPR to the fuel rail, and it's starting to show some seepage. I hoping to find a good used one. I really only need the line, but wouldn't mind having another FPR around either. Thanks!
Richie
Re: 3b FPR and line
Might not be a bad time to replace the other braided line as well... This isn't the first time we've seen one of these fail.
uberaudi
Re: 3b FPR and line
Post by uberaudi »
Good to know, thanks Chris.
So now I'm looking for the whole set. If anything, as spares.
uberaudi
Re: 3b FPR and line
Post by uberaudi »
Anyone?
varia
Re: 3b FPR and line
Post by varia »
i have these, if its helps
¯\_(ツ)_/¯
project 2226
uberaudi
Re: 3b FPR and line
Post by uberaudi »
The two longer ones would be good to have for spares, but I really need the one that goes from the FPR to the fuel rail. ..threaded to banjo fitting.
Had to reschedule my inspection today for the track event next month...gotta find one of these!
uberaudi
Re: 3b FPR and line
Post by uberaudi »
It's part number 034 133 717 T if that helps. And it's not a braided hose, my mistake. It's just a crimped rubber hose.
uberaudi
Re: 3b FPR and line
Post by uberaudi »
Still need this!
uberaudi
Re: 3b FPR and line
Post by uberaudi »
Found an alternate solution, no longer needed.
