Question about adjusting the subframe, B3 80.
Isn't one of the subframe bolts stationary while the other 3 are adjustable based on the stationary's pivot point? I'm wondering if I can loosen the transmission bolts and the subframe bolts and adjust the subframe and ultimately the control arm back towards the rear of the car about 1/4".
Subframe Adjustment Question
Re: Subframe Adjustment Question
Well, to answer your question...
Yes, the closest subframe bolt to the driver is stationary and is the pivot point to allow side to side/forward and back on the other 3.
- themagellan
