Replacement O-rings for 034 Injectors?
dalspaugh
Post by dalspaugh »
I bought used 034 Injectors and need to replace the O-rings
There are 3 different seals to replace:
Adapter to Fuel Rail - Done - ordered from 034, everything is good
Injector to Adapter -??
Injector to Intake Manifold - I tried this:
https://smile.amazon.com/gp/product/B00 ... UTF8&psc=1
and the ID fits well on the injector, but the OD seems to be slightly too large for the IM.
So, what are people using to replace these O rings?
'95 Audi 90Q
'00 Buell X1 Racing Stripe
Re: Replacement O-rings for 034 Injectors?
I'd try a local shop that cleans injectors, they usually have large oring assortments you could pick through.
dalspaugh
Post by dalspaugh »
ringbearer wrote:I'd try a local shop that cleans injectors, they usually have large oring assortments you could pick through.
:thumbsup: Alright, solid plan if no one on here comes up with something. I was thinking I'd just bring the IM and injector into a NAPA and just sift through...
'95 Audi 90Q
You used to be able to contact 034 for replacements. Don't know if you still can though.
dalspaugh
Post by dalspaugh »
DE80q wrote:You used to be able to contact 034 for replacements. Don't know if you still can though.
Makes a lot of sense really... maybe I'll give them a call for info.
What I found tonight is that the
ID of the boss on the IM is ~13.9mm
OD of the O-ring I've been trying to shove in there is 15mm.
9/16 in = 14.29 mm which I think would be a good fit.
So I'm trying to track down a 9/16" OD x 5/16" ID set of o-rings. Then need to confirm fitment and seal under pressure (could be a while at my rate of working...)
'95 Audi 90Q
dalspaugh
Post by dalspaugh »
'95 Audi 90Q
varia
Post by varia »
Multipurpose O-Ring, Oil-Resistant Buna-N, 3mm Wide, 14mm ID
http://www.mcmaster.com/mv1460752213/#9262K271
¯\_(ツ)_/¯
project 2226
dalspaugh
Post by dalspaugh »
varia wrote:Multipurpose O-Ring, Oil-Resistant Buna-N, 3mm Wide, 14mm ID
Thanks for Varia, but I need 14mm OD, 8mm ID. I really think the one's I ordered off Amazon will work well, they come in tomorrow.
'95 Audi 90Q
varia
Post by varia »
what i posted is for the 034 adapters.
¯\_(ツ)_/¯
project 2226
dalspaugh
Post by dalspaugh »
0ooo, gotcha!
thanks for this little pseudo-drawing of the adapters! For the o-rings from the adapter to the fuel rail, I just ordered those straight from 034, fitment is nice and they were cheap (since I was ordering other stuff too...)
got the amazon o rings in last night but didn't have a chance to check fitment. This weekend.
'95 Audi 90Q
