GURUMAN wrote:Hey Aron, are you gonna pull from this huge catch can ?
with this:
or even more agressive:
Those exhaust evac valves suck, they barely flow and never pull a vacuum. I have measured....
A properly built catch can is all you need. The breather on the yellow car is still dry at the outlet.
speeding-g60
Post by speeding-g60 »
a little fumes is all the rabbit gets. it is -12AN of VC and -12AN off block.
this catch can is just something i thought up. it CAN be replicated. if i had dimensions, etc, i am sure the guy who made mine would make a couple more. he does this type work as his side work from home. he has his own little workshop.
its design is posted back a few pages.... but basically, a baffle plate directs gases downward, and the filters sit above said plate. the plate is not connected to back wall, and has drip holes drilled into it.
it even has a block drain-back port. i think it will work out just awesome really. next step would be dry sump....
the breather on the rabbit never sees oil yet, its clean, and not much of anything has even drained out of it.
That just makes me think of what a good investment a welder and some good time on one would be.
Man definitely does some nice work! Good stuff
speeding-g60
gotta love the minimal points for boost leaks. how does one v-band, and two couplers sound??? one single boost pipe. 3.5" OD. simplicity, i love it.
PTown Love
Post by PTown Love »
Very nice.
Wrap that exhaust manifold to keep all the energy in it and not lost in your engine bay. Heat in your manifold = energy to spool your monster turbo.
:woowoo:
speeding-g60
oh i plan on it. i have to take it off first :D after i fit everything to it...
so i have some detailed pix of the turbo mount, and some couple shots of the manifold... dual wastegates, open dump tubes separate from each other.... true twin-scroll manifold setup.
Interesting indeed. Having the flange attatched to the frame rail like that seems sketchy for whatever reason, but I am sure it is going to be fine.. I mean, the thing is solid mounted, but no thermal expansion is going to even have a glimmer of hope.
Looks flowalishous for sure though!!!! :woowoo:
PTown Love wrote:[/quote]
Very nice.
:woowoo:[/quote]
honestly, its such a minimal effect that the added weight of the wrap probably offsets the quicker spool time.
Thermodynamics at its finest.
speeding-g60
i understand the thoughts..... really. but the motor is solid, the trans is solid. the guys who built it for me, they do this. their shop car is a 66 nova that runs 7 sec 1/4 on DR's and is street driven. its badass.... 100mm turbo? yeah they got one on a small block.
5" exhaust. they run a motor plate style mount, solid as can be. and the turbo has the same type of solid mount.
derracuda
Post by derracuda »
where'd those Y junctions for the header come from? those are nifty...
s2 on the way
Post by s2 on the way »
:woowoo:
more and more can I not wait to see this thing in action.....
then you and Janis can battle over who can break more drivetrain :wink:
it seems to be getting pretty close eh? any timeframe you're working with?
speeding-g60
great. he is far ahead already....
D, i dunno where those EXACT ones came from, but i know a place in St Helens that makes them..... www.mandrel-bends.com
located here: http://www.mandrel-bends.com/catalog/co ... formed-51/
but i tossed the stuff together, as the paint "buddy" is bein a little bitch and backing out on HIS suggestion to paint this weekend.... :curses: :curses:
but i tossed it all together right quick, and this is how it looks....
zerb
Post by zerb »
nasty. :woowoo:
I formed 5 projects off that link you just posted Aaron.. Thanks :roll:
s2powerusa
Post by s2powerusa »
thats gona be sickk cant wait to see a videoo
awsome project men
speeding-g60
ShavedQuattro wrote:I formed 5 projects off that link you just posted Aaron.. Thanks :roll:
WOOWOO!!!!!
gotta love new projects when old ones arent done yet. i love it MUHAHAHAHAHA
looks fast
PRA4WX
Post by PRA4WX »
Looking nice! 8)
speeding-g60
worked on skirts. mounted, dont really like the way they need to mount but whatever. it is what it is. they have to mount that way. but its a race car so it dont matter.
paint dont match. the new batch of paint has more red/blue tinting to it than original. since i have plenty to do the car in the new color, that is what it will be. i like the color anyways.... primed the quarters. taped out lights/wing. shitsack bailed on the painting of it this weekend. crappiest part about it was it was his idea and his plan. douche anyhow.
worked on fueling. mounted cell. bracket for pumps. short one fitting (go figure).
made front tow rings/tie down loops, what you want to call them.
i just cant get over how good this looks... really. also, i wasted alot of time on lame household stuff, like weedeating the side of the house (getting deep in my steel yard LOL) drain/refill pond (it needed it, didnt know i have 7 fish :o ) and basically did lots of thinking on the car stuff.
got radiator chosen, ordering it tonight. designing the coolant reservoir. i like building stuff. also welded some aluminum. getting good :) welded the tabs onto the fuel cell.
the color of the door is the final color of the car.
:drool:
zerb
Post by zerb »
and the radiator you have chosen is...
Frank the quattro tank
Post by Frank the quattro tank »
Don't melt the front right tire.
speeding-g60
zerb wrote:and the radiator you have chosen is...
not so cheap, but not bad considering some of the others i was looking at. it has the 1.25 in/out ports i want to use. the other has 1.5 in and 1.75 out. yes, you will think it has ports on the wrong side. BUT, i am going to flip it upside-down. it wont know the difference, its dumb. thus also why i chose this one, no fill neck. i make my own coolant reservoir, just like the rabbit. you gonna like where thats going LOL.
i should have some sort of stock in Summit Racing. man i waste so much money on these cars.... (mutters, shakes head, thinking of how much actually spent)
http://store.summitracing.com/partdetai ... toview=sku
speeding-g60
yeah, Frank. i have not yet coated/wrapped anything. still playing it all out how it is all going to finally fit together....
but its on "the list". that and a crap load of other stuff....
oh i forgot to ask...why fuel in the front? simplicity?
