I hear ya - I wanted to use the top outlet of the IC to TB route, but it required some sharp bends in the pipe to make it work due to the top of the center support and the hood release cable and I didn't want to start cutting that up and putting in hood pins. I'll rework the end tank so that the new outlet will be the most pronounced (instead of leaving it at the top).super5 wrote:Just my 2cents., extand the end tank on top go with most direct angle too the TB from the back of the intercooler and put the blow off valve on the lower part of the tank of the intercooler.
I was thinking about the BOV on the IC too, but space is pretty tight up there.. Haven't given up yet though
