Nick's Black 90 - 3B Swap: Running!
Re: Nick's Black 90 - Ghetto 20vt: Collecting Parts
Once you identify the various sensors in the harness it really isn't THAT bad.
nsimps
Post by nsimps »
Funny you posted those pics Chris, no sooner I had posted I went straight to your build thread :) the good thing here is I have a 7a and 3b harness to splice while my car is still being driven. The more I look at the grime and rust the more I get overwhelmed. But I bet once things start coming off it will go smooth. Next step is to get it mounted to the stand.
savagerocco
Post by savagerocco »
It will go quick nick, before you know it you'll be putting 20k on the motor, unless you hang around. Hank Darin or me.... Then it might be more like 20k into the motor.....
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
savagerocco wrote:It will go quick nick, before you know it you'll be putting 20k on the motor, unless you hang around. Hank Darin or me.... Then it might be more like 20k into the motor.....
:lol:
nsimps
Post by nsimps »
:lol: :D :lol:
I keep telling myself that stock boost levels will be just fine.
Stock boost levels will be just fine
just
fine
for now...
:lol: Good one.
scubadave
Post by scubadave »
Its a slippery slope
chipped ecu levels with stock everything else is quite fun Nick. you may be happy there.........UNTILL.......
Stock will be fine for a month max :)
Just get it in and sorted then save up for power mods.
nsimps
Post by nsimps »
Update:
Took some preliminary pics of the motor to have some before/during/after fun.
That's look pretty daunting, but you'll get through it. I think once you take every thing off and do it piece by piece it will be more manageable. I think you'll definitely want to replace as many seals and gaskets as you can else all the work you'll do to get it clean will be wasted if it's still leaking oil and fluids.
nsimps
Post by nsimps »
I plan on doing the pan, valve cover, exhaust, intake, coolant rail, timing belt kit. My hope is to make sure the torque is good on the head but leave it as is. If I absolutely need to it will be pulled, but it would add 200.00+ to my budget. My goal tonight is to get it on the stand, get some PB blaster and soak it.
You should also do the front and rear crank seals and I'd consider the cam seal as well.
nsimps
Post by nsimps »
I put those on the list of things to pickup. What about the rear bearing?
nsimps
Post by nsimps »
Update:
Got the motor on the stand. It may seem like an easy task and I thought it would be. An hour later it was safely off the picker and resting level on the stand.
My dear wife was doing a vocal session at a local studio and so on I went. Starting with the intake side, I proceeded to take things off. Only one bolt has stripped and gratefully it didn't impede me to keep moving forward. Taking the fuel rail off was the most nervous part of the whole thing and luckily none of the injectors broke. Two of them are still on the head but they should come off easily enough (fingers crossed). After getting the bigger mounts and pieces off I proceeded to take a pick and scrape. And scrape. And vacuum. And scrape. And vacuum. Scrape some more. Get the stink eye from... Scrape some more, vacuum then done for the evening. This thing looks like it has been sitting for a while but turned over by hand freely. I think there's still oil in it but haven't pulled the plug yet. That'll be after the exhaust side has all been removed. Let's just hope I can put all this stuff back together!! I plan on bagging all the bolts and labeling as best I can. Then going to the local bolt supply and picking up as many new ones as possible.
Next step is to clean up the garage so there's no more tripping over things and somehow get more vocal sessions setup for my wife ;)
Any suggestions on how best to paint the block? I was thinking of doing some Rustoleum inhibitor and then finish it with gray like Chris(Wheeljack) did. Also need to try and find someone local with a media blast booth to clean up some of these parts so they look pretty.
Cylinder One
Cylinder Two
Cylinder Three
Cylinder Four
Cylinder Five
Scrapped
The mess. This doesn't account for everything else in the shop vac.
Nice 8)
Hybrid_Hatch
Post by Hybrid_Hatch »
shop vac? :)
nsimps
Post by nsimps »
Hybrid_Hatch wrote:shop vac? :)
That thing came in handy the very next day after you handed it down. Been grateful for it ever since :)
Nick, go down to the lab and snag the red cabinet. I think it has pretty aggressive media in it, but you can always get some bead from harbor freight. Do you have air?
ShavedQuattro wrote:Nick, go down to the lab and snag the red cabinet.
Grab the lift too. :D
nsimps
Post by nsimps »
ShavedQuattro wrote:Nick, go down to the lab and snag the red cabinet. I think it has pretty aggressive media in it, but you can always get some bead from harbor freight. Do you have air?
Woot, thanks! I have a small compressor that should work. If it breaks that will give me a reason to upgrade :)
You may want to put new glass in it. Pexi or lexan works well if you aren't willing to get real glass. Might take you a few minutes to use the glass in there as a tempalte, but you will probably save time in the end.
savagerocco
If you have rock gaurd it works great to keep the glass from frosting too quickly....
scubadave
Post by scubadave »
may as well upgrade now. I have an 80 gallon 1 stage 220v compressor and it has a hard time keeping up with constant use. it realisticly runs fine for 5 then let it catch up for 5 and so on. a little compressor will only run for about 20 seconds, then 5 mins to catch up, ect ect.
nsimps
Post by nsimps »
Thanks for the tips :) Hank I took the existing heavy stuff out and put in what I think was #8 glass that was in a box right by the booth at the lab. I'll probably end up with some less expensive media and hopefully upgrade compressor sometime this year.
No real progress on things today other than cleaning up the garage and getting back to organized status.
Thanks again Hank, having a booth in the garage is a big upgrade to the garage build!
Careful with the glass. I don't know what it was, but it is a reasonably good idea to have safety glass in the cabinet. Your face is pretty close to glass when you are blasting, and if a bolt or small pebble hits the glass just right, you could have an eye full of glass.
