derracuda
Post by derracuda »
yeah, that was the idea :D. i'm going to take my car to a hydraulic shop up at home, take my plastic car ramps and not come home til' i have some nicely routed hardlines made up with flexible ends.
derracuda
Post by derracuda »
i redid my camber plates, but haven't gotten the chance to install them yet.
Post by Matt »
Looks nice!! Want to make me a set?
derracuda
Post by derracuda »
ok, for right now, the camber plate idea is out. i've just got too much on my plate to deal with figuring out everything so that it works properly. i do have good news though....
taillights
and steering wheel!!
and wires!!! *hugs* :P
blah, there's so many wires!!! here's what i'm doing and why i'm doing it. i'm installing the autocheck system because the 5kt dash cluster doesn't have an oil pressure warning light... and i can't go without that. so the plan is to hook up the few features that my car can incorporate into the autocheck system, and then set up a dummy "ok" signal for all the rest so that the autocheck will still go through it's normal functions and keep me aware of the pertinent ones on my car. plus it'll look cool to have that actually working when the key is turned on and the dash comes to life.
note the bentley and another printed out wiring diagram...
so far i've weeded out about everything i don't need (wipers, radio, center console stuff). i just have to go through one wire at a time and hook it up and test it. i need to actually get power to the dash cluster itself so that as i hook stuff up, i can verify. i did get the fuel level gauge working already :D after this is done, then i have to work the turn signal/combo switch setup into the mix. yay :roll:
it's just uber time consuming and not very stimulating, but i know that i need to get it done so that i don't procrastinate and have a bunch of stuff left incomplete when the car is actually on the road.
Lt. Sarge
Post by Lt. Sarge »
Is that the steering wheel you got from that one guy? I think I might need to plan for one of those...when I have some money. Looksa pretty-pretty nice!
audibeans
Post by audibeans »
Is that an Stebro exhaust?
derracuda
Post by derracuda »
yes and yes. the steering wheel is from CAC's paul fernandes of luxembourg (same with the taillights), and the exhaust is infact a stebro. it's nice and quiet.
Post by AudiSport4000 »
Looks like fun :D
derracuda
Post by derracuda »
hmm, ok, maybe i can save me about 10,000 headaches....
4kq light symbol plate...
4kq light symbol plate after weight savings program..
5kt light symbol plate missing the door open light symbol (whoever needs a light to tell them their door open is :dur:)
loctite brand superglue to the rescue!
noticeable modification here....
not noticeable here 8)
ok, now i'm going back at it with the harness to eliminate all the autocheck garbage.... i jumped that ship pretty quickly :P
Highlander
Post by Highlander »
Looks good Derek,
I'm in the middle of splicing the AAN harness into the urq.
Boring work but important never the less.
Cheers,
Craig Cook.
200 Avant
Post by 200 Avant »
Thank you... Thank you.. thank you for the update... My addiction has been satisfied for the day. Damn it's looking sweet. I certainly don't envy your wiring maze from hell... Patience grasshopper and you will prevail... :bashtard:
derracuda
Post by derracuda »
Highlander wrote:Looks good Derek,
Cheers,
Craig Cook.
yeha, no doubt. the autocheck system would have just been there for the "neat" factor. but as long as i have the oil warning light, i'll be happy :)
and you're welcome 200avant :P
s2 on the way
Post by s2 on the way »
:stupid:
wanna build me my next car??? :D
derracuda
Post by derracuda »
s2 on the way wrote:[/quote]
wanna build me my next car??? :D[/quote]
maybe :)
s2 on the way
:thumbsup: sweet,,,
i just gotta finish this one first :wink:
audibeans
Post by audibeans »
derracuda wrote:yes and yes. ...., and the exhaust is infact a stebro. it's nice and quiet.
Cool, everyone knocks on Stebro for low quality, but I love mine, sounds awesome.
Looking great, such detail...:)
derracuda
Post by derracuda »
welll.... i wouldn't rate it the best built quality. if you look at my tailpipes... they hang a bit low, and i can't make them go up any higher because otherwise it will come into contact with the underside of the body. and as for the cannisters, they are just hand welded, nothing really special or fancy. i would say the best thing about a stebro is that they are SS and won't rot out. for some weird reason the one i have is really quiet. my friend has one on his 4kq that's NA and it's way louder, but this same exhaust was on my zermatt car from NC and it was OEM quiet on that car. just odd IMO.
The Stebro with the 7A sounds much different, which I really like. There was a Zermatt 4kq at Carlisle years ago with a Stebro and it was very quiet.
Kind of a pointless post, but ya know 8)
audibeans
Post by audibeans »
derracuda wrote:welll.... i wouldn't rate it the best built quality. if you look at my tailpipes... they hang a bit low, and i can't make them go up any higher because otherwise it will come into contact with the underside of the body. and as for the cannisters, they are just hand welded, nothing really special or fancy. i would say the best thing about a stebro is that they are SS and won't rot out. for some weird reason the one i have is really quiet. my friend has one on his 4kq that's NA and it's way louder, but this same exhaust was on my zermatt car from NC and it was OEM quiet on that car. just odd IMO.
Yep, mine hangs exactly like yours does in the pic,...bugs me a bit but oh well.
Yeah, mine is also, super quiet, sounds a lot like my niegbors' M3...
nismo
Post by nismo »
My Stebro for my CQ was really loud when I got it last year, and got quiet for a while (deafness?), but after I 'blew the carbon out' its back loud and I like it.
I have a feeling some critters may have made a home in there, and I finally got that isht blown all out.
Eric
cuatrokoop
Post by cuatrokoop »
OE center vs Stebro center vs no center also makes a HUGE difference. The stebro on the 7A would set car alarms off in conjunction with the Jamex air filter, and it sounded pretty darn nice. No idea how it will sound on the 7AAN3B mutt.
Longitudinal
Post by Longitudinal »
AudiSport4000 wrote:The Stebro with the 7A sounds much different, which I really like. There was a Zermatt 4kq at Carlisle years ago with a Stebro and it was very quiet.
Now that I have seen Derek's, I now know that my 1985 4KQ had a Stebro exhaust. PO had deleted the cat. This exhaust was rather loud under acceleration and droney during cruise conditions. Maybe it would have been much better with the cat. I am sure it sounds much better with a turbo.
derracuda
Post by derracuda »
ok, breakthrough! last night i got the tach to work!!! WHOO HOOO. i played around with it for a while before but i missed one ground wire for the tach. there's just so many wires :P so i now have an operation fuel gauge and tach... that's half the display. now for the temp gauge and speedo. maybe i'll get a video of me starting it and revving it a bit :D bbiab..... *runs out to do so*
derracuda
Post by derracuda »
Awesome video. I really, really like the 5000 turbo clusters. Not sure what it is about them, maybe the faces or the lighting, but they are one of my favorites.
Nice work!
