[/quote]
Re: 24v vr6T coupe quattro Project: EATSGTR, grand opening!!
death 4kqt wrote:[/quote]this thread needs more pertinent pics
[/quote]
[/quote]
Re: 24v vr6T coupe quattro Project: EATSGTR, UPDATED!!!
first page updated
my2000apb wrote:first page updated
i jsut put 100+ chassis pics up on the first page, please check them out
we are pretty much up to date so all further updates will be on the last page
Re: 24v vr6T CQ Project: EATSGTR, epic page 1 pic UPLOAD!!!
Mmmmmanifold
That's a 3" velocity stack for sizing reference...ought to be plenty of volume
Attachment ( 26263 ) : 2011-04-26_21-24-27_598.jpg
90 Coupe Quattro - 3b + 01e
87 4000 - future trail rig
yes manifold fabrication has begun
update to come
update to come
Animals. Bloody nice work. Jealous of the rear diff.
its something you could doShavedQuattro wrote:Animals. Bloody nice work. Jealous of the rear diff.
torsen or locker in a sub 30 minute swap
ah the decisions
did you get my txt about the rail injector size?
jbrentd
nice project...subscribed
Highlander
Sweeeeeeeeeeeeeet!
This is going to be a good one. My favorite kind of build........HARD CORE for sure.
Great workmanship guys.......I'll be following this closely.
Thanks for sharing
:cheers: :cheers:
Craig Cook
Thanks for sharing
:cheers: :cheers:
Craig Cook
varia
Subscribed......
but post more info/pics plz!
thanks guys, ill be home tomorrrow and many pics to come
intake manifold fabbage
subframe, lots of mods = might as well be reconstruction, i will def be making a fullcustom tubular subframe once shes up and running
id like to tuck it up into frame a bit more and raise c-arm mounting postions
valve cover mods
front radiator / fmic plans
valve cover mods
Highlander
Now your just teasingmy2000apb wrote:thanks guys, ill be home tomorrrow and many pics to come
valve cover mods
:slap:
yup hehehe i suckHighlander wrote: Now your just teasing
:slap:
the pics are worth the short wait
audidub
speaking of intake you get the stock cut for the runners??
autoholic
Damn, nice car. You guys do some amazing work. I'd love to check that thing out sometime.
thanks, swing by, youre barely an hour awayautoholic wrote:Damn, nice car. You guys do some amazing work. I'd love to check that thing out sometime.
yup ready for your skillzaudidub wrote:speaking of intake you get the stock cut for the runners??
well i have some extra plenum stock, ~6" so im thinking i might buy one more alum. hemisphere and make a coolant expansion tank.
a_CQ
Why? It will be 10 times heavier than OE plastic ones that work just fine. Get a smaller ball size one form newer VW/Audi if you need realestate.
Why not build/raise the subframe right away vs. later on??
well firstly, it def wont weight 10x a stock plastic one, it will be a bit heavier, but also show me a way to attach AN fittings to the plastic resevoir.a_CQ wrote:Why? It will be 10 times heavier than OE plastic ones that work just fine. Get a smaller ball size one form newer VW/Audi if you need realestate.
if i come into extra time etc ill start building a subframe, right now the modified one works and will work fine to get the car rollign and driving, i can take a bit of material off of the upper portion of the subframe bushing to tuck the subframe a bit more. i will start building the v1.1 versions of parts once its further along and being refined not built first time around
Update time,
Motor is back in for a short time
The vr6 24v valve covers have a bump in them for the breather. The valve cover is from a transverse application. As you can see in the pics the VC has to be trimmed down so its not interfering with the hood. So I cut the breather portion off and made an aluminum plate to block the opening off.
Its now tig’d up by Ryan @ Higbee fab, and its back on car to test fitment.
i will be replacing the breather that i removed, probably with one large or two midsixed bungs off the front-facing oil filler cap hump thats in the VC.
so, a few breather bungs, some powdercoat and its good to go
More update!!
So I finally got a chance to tear into the cylinder head that I will be running. Its going to be stripped of all components, ported to r32 intake sizing (more on that to come), cleaned up and rebuilt.
The head has 68k miles and looks pretty clean
On to the PICS!!!
On to the PICS!!!
fasterthenrs2
nice project me like
Gonna be a ripper
does jimmy wnat an update?:)audifreakjim wrote::bump:
ive got some juicy pics
