Nick's AAN into 4000Q thread. set backs.....set backs....
Re: Nick's AAN into 4000Q thread. IT RUNS!
Looks great man!
40v4kq
Post by 40v4kq »
Nice. Should be a hoot when you get to drive it. Dont forget to get the first drive on video.
Dan
1984 Ur quattro
1987.5 Coupe GT Special Build
Nollywood
Post by Nollywood »
Awesome work!
no video yet
Rallyfreak202
Post by Rallyfreak202 »
Thanks for the kind words guys!
To do list:
-turbo bracing
-exhaust (get piping, hangers, and figure it out)
-headlight wiring
-take proper reving video.
-figure out why the engine cuts fuel when MAF line is plugged into ECU (034 1b)
-some misc. stuff
I hope to make it to Quattro De Mayo in Georgia in the beginning of May...
and then Southern Worthersee in mid May...
my2000apb wrote:...no video yet
Here is a very poor quality video Tim! I'll get a good GoPro quality one up over Spring Break. Hopefully a little drive too!
Link to video
Sweet! Congrats man!
JT4k
Post by JT4k »
Flipping awesome! Congrats.
Rallyfreak202
Late and over-due update lacking in photos. I got the tune issue worked out with the help of audifreakjim and some others. Thanks guys!
Over spring break I got to feel this thing boost!!!!! :woowoo: :woowoo:
Turbo bracing material:
IMAG0398
Wired up my gauges to the dimmer switch
DSC_0920
Hella dual air horns
DSC_0925
mounted the ECU
DSC_0916
Front support brace with hood latch. I used the strut tower brace from my UrS4
DSC_0896
DSC_0895
Oil was leaking out of the oil line for the turbo. I realized I never had a gasket in there...so I made one. NO more leaky!
DSC_0928
Check it!
DSC_0913
To do:
-turbo support bracing
-get exhaust made
-learn how to tune and not blow up my engine
-boooost
40v4kq
Post by 40v4kq »
SICK! It sounds loud...just right. BTW, i'm completely jealous of any 4kq with quattro script interior. I like my leather, but seats that have "quattro" all over them are just plain awesome. Oh, and Ben is a jerk for scoring a set of quattro script seats at a wrecker. LOL
Dan
1984 Ur quattro
WAUG0806
Post by WAUG0806 »
nice.
I'd like to see how the turbo brace worked out.
WOOOOOT
Rallyfreak202
Re: Nick's AAN into 4000Q thread. turbo bracing
A lot of progress has been made in the past two weeks. I'm out of college for the Summer and back home. Here are some photos of the turbo bracing. I used 1/2" 304 stainless steel and the rest was sourced from my pile of misc. brackets and metal around the shop. Making the bracing took longer than expected.
My tube bender:
y u no clear hood? Had to make some "provisions"
Had to clear the coil cover
Rallyfreak202
After the turbo bracing was finished, I moved on to the headlights/blinkers wiring. I hated this part.
Rallyfreak202
Got it all the headlights wired up, blinkers work, mounted the grille, misc. wiring for gauges, and it is almost done.
Benny expressing his excitement!
death 4kqt
Post by death 4kqt »
awesome man, just in time for summer.
Spidey
Post by Spidey »
Looks great! ;)
more vids
Rallyfreak202
Re: Nick's AAN into 4000Q thread. set backs...set backs....
my2000apb wrote:more vids
Is your 16vt 4k done yet?
Fuel is pissing out it's line. Time to fix it.
My rear main seal is leaking (which I replaced during rebuild) and spark has disappeared. I think I have too much crank case pressure and it is pushing out thru my rear main seal. I don't know why the main seal would just start leaking (a lot of oil) suddenly.
Rallyfreak202
Re: Nick's AAN into 4000Q thread. Question about spark
I need some input guys. I am not getting any spark. I took a video of me taking the wire from the coil and putting it next to ground. There should be more frequent spark correct?
Also, does it matter if I use a multi window distributor or a single window? I am using single window right now but did have a multi window one installed.
TheArchitect
Re: Nick's AAN into 4000Q thread. set backs.....set backs...
Post by TheArchitect »
I am unaware of if you are using your distributor to trigger the 1B ECU for ignition or if you are using the stock ECU to control your ignition, but either way, you will want the multi-window (4 in your case) to trigger the 1B ECU.
The 1 window distributor is used for sequential phasing of the stock flywheel sensor (when used with the stock ECU) or used as a cam synch for distributorless aftermarket ECUs.
Rallyfreak202
I am puzzled guys. It will not start, ONLY sputter a little bit. The sputtering is just a thud notably heard from the open down pipe.
I am getting weak spark and I don't think it is sparking as often as it should....about 1-1.5 spark a second(battery is charged). Is that too little? It is also a yellow/orange spark.
I am using 034 1B controller and have my ground trigger wire going to the - side and my 12v wire going to the positive side of the coil. Those are the ONLY wires on the coil.
ANY advice is gladly accepted.
Rallyfreak202
Re: Nick's AAN into 4000Q thread. Stumped on no start.
Is fuel pressure ok?
ShadyUrS4
Post by ShadyUrS4 »
badass Nick can't wait to see the car when you have it down at western!
Rallyfreak202
Resumed working on the 4000!I need to get this thing running before I go back to school.
Still have weak spark off the coil. I have 12v while cranking to the positive side. The negative side of the coil is the ground trigger from the 1B controller. The coil is good, tested it on my GTi.
Just asked The Architect what he thinks. We'll see.
ShadyUrS4 wrote:badass Nick can't wait to see the car when you have it down at western!
Thanks Lane.
