Hanks URQ 2.6L Autopsy
cuatrokoop
Well, dont kill yourselves!! I have a buddy with an s4 nearly all stripped out in the garage a few blocks down, I just thought that ifsomebody had gone torsen, and still had the old cups layin around, it would be easy to talk them otu of them and keep this s4 diff in tact.
Very Nice of you guysthough. Thanks
Quattro v1.0
- ralleyquattro
quattro v1.0 wrote:[/quote]
Im going to put this back on track...
Hank, paint it GOBI ;o][/quote]
I like Gobi, it was my first Audi, 1982 Coupe... that color grows on you.
Not to mention you can go two years without washing it BTDT, does not show dirt at all... mud just blends in..
Martin Pajak
http://www.quattro.ca
82 Audi Ur-q, SQ project
83 Audi 80 q, Euro 2-Door
85 Audi Ur-q, Euro mit 3B
91 Coupe Quattro
91 Coupe Quattro
zarati
germantoy
nismo
ShavedQuattro wrote:
I kindof like that color. I this stone Gray?
This is I believe
Black is fast, but I Vegas and Black dont match at all. If I didnt have to wash it myself,paint it myself and had AC, black it would be..
Can somebody confirm if htis is the same color, and if it is, what color/code is it? I think it is the winner.
Quattro v1.0
Darker the grey, and it starts to run into the same problem as black.. Hard to paint, hard to maintain and hot.
I do not want a garage queen. I want to drive it on big road trips, do track events and rip past 18 wheelers without getting the hebbie jeebies.
Hopefully the white strips off very easily. I have messed around with paint stripper a bit and it takes that 2mm of white crap off quite nicely. Hopefully I can get it down to port rose and just spray over that.
Quattro v1.0
Soon hopefully. I got a bunch of projects that take priority, but after they clear up... I am going to Fremont at the end of May for a dyno session with the 034 boys. I want to roll the fenders slightly by then and lay some paint on it. I probably will not go uber crazy on the paint, as evenutally I want to scrap the undercoating, add underbody support to stiffen up the car. I spend time making the body straight and then put a quick spray job on to keep it from rusting/corroding till I have the time to strip the car down to the frame. I really want to get fiberglass fenders and hood too, so It seems a waste to spend too much time painting those really nice.
I could paint it with a paint brush and end up with a better job. It is that bad right now.
Well I have been running the 35r for the last 5k miles or so. It took out my 016 in fast order. So I have been driving it around wihtout a second gear for a couple of months, enjoying the great weather. I have been itching to build a new header for a while. My old Ebay piece was a nice manifold, but I hated when people looked at the car and asked if I made the header too, and I could not claim it.
So I decided to make a new one. I have always been wanting to do a v-band inlet like Matts(lowlyoilburner), and he just fueled the fire with his build. I have been finishing the semester with little to no time, but I did get a couple of hours this week to dink around with a new header. I was hoping to finish up this afternooon, or weekend, but between finals, and my sister having a baby, I dont think it will happen.
I spent a the majority of the time makign it equal length. All the runners are at 9.5" plus or minus an eighth of an inch or so. Schedule 10 304 pipe with 1018 head flange. So I will be running the 35r still with the tial housing, and I am sending the turbo in to Forced Performance to get a billet HTA wheel put on. They advertise 400rpm faster spool up with the billet wheel, and Tial advertises more power and slightly faster spool with their housing. I am hoping to get power down to the 4500rpm range down from 4900 I am seeing now. If I can get the same power with that spool up, I will be a happy camper. The HTA35r is suppose to flow 7lbs/min more air as well so I hope that with e85, I can make around 600whp with this setup, reving to 8500. That will give me a fat 4k of nasty power.
So I want to go to Javad's shop on the 27th of May for a dyno session and enjoy the bay area with my wife. Here is the list of things I need to get done to make it happen..
Header and downpipe built
-EGT bung
- Lathe out flanges for wastegate
-get tial clamp
Turbo brace
Radiator recore.
Front suspension
- cut delrin front control arm bushings
- either cut new
-Front subframe mods
- Holesaw subframe mounts to allow for more caster
-waterjet out sliders to be welded in
-Seam weld the subframe.
-Repaint
Engine mods
- Swap head for Darin's rebuilt head
-inspect pistons
- deck the valve cover flat
01e needs
- weld in provisions for pilot bearing
- order new pressure plate surface if damaged
- make passenger side rs2 replica mount
- get slave cylinder
- make fitting for slave cylinder
- modify linkage
016 torsen needs
- Change fluid??
- use Southbend pressure plate
Rear Diff needs
- Change fluid
- exchange cups from s4
- install rear diff mount in polly
Rear suspension
- Remove entire assembly
- seam weld subframe
- press out old subframe mounts
- install aluminum subframe mounts
- inspect ball joints and rear links
Exhaust in Aluminum
-Make muffler
- Order perforations
- decide on material thickness
- spin 5 v-band ferules for exhaust
-order 3" tubing
Monitoring needs
-Order Vapor module
- Mount speedometer
-Figure out tach input
- Fuel gauge
- make custom dash
- Wideband 02
-EGT
- Get probe as well
-coolant
-Oil temp
-oil pressure
-Boost gauge
-Volts
Iic upgrade
- get new firmware
-Wire in WB into ECU
E85 needs
- Make surge tank
- Decide on fuel pumps to use
- Order -10 line or tube
- Make tank to surge tank in big -12 feed
- Wire relays for fuel pump
Interior Needs
- transfer script interior for black seat
- get a hold of a black rear seat
-EGT bung
-get tial clamp
Turbo brace
Radiator recore.
Front suspension
- either cut new
-Repaint
Engine mods
-inspect pistons
01e needs
- modify linkage
016 torsen needs
- Change fluid??
Rear Diff needs
- Change fluid
Rear suspension
Exhaust in Aluminum
-Make muffler
-order 3" tubing
Monitoring needs
-Order Vapor module
- Mount speedometer
- Fuel gauge
- make custom dash
- Wideband 02
-EGT
- Get probe as well
-coolant
-Oil temp
-oil pressure
-Boost gauge
-Volts
Iic upgrade
- get new firmware
E85 needs
- Make surge tank
Interior Needs
a_CQ
I may sacrifice the 016 in the name of a deadline. I dont want to, and feeding it to the 35r, is just that.. BUT, I do not think I will have time to figure out axles, linkage and change my flywheel/balance it before then. If I do the 016, it will be plug and play. I'll use the new firmward to limit boost in 1st and second gear to save the 2nd gearset.
I would like to paint it as well prior, but I doubt that will happen as well.
