Hahaha. When you're in the moment it's easy to feel overwhelmed. You've got to understand where I'm coming from though... let me try to explain a little bit.
A brief history of my experience with the car: bought the car, found out it needed a new engine. My plan was to just tune it and drive it but it started really consuming oil so that wasn't an option anymore. So I rebuilt it with the best that I could afford, which was a built block but no fancy header/fuelling. Overall a solid build for ~400whp. It took a few days to get going as it was a setup I wasn't familiar with, but it got there. Then of course there's the Carlisle Saga, which could have been enough to make anyone else sell the car. But I (and by I, I mean dad and Craig) slapped another built engine together and swapped it in. Except it wouldn't run right, tons of issues. SO I go about diagnosing it starting in early June. It takes months to get my ECU back only for it to be broken still. Then it takes a month to get my new ECU. I can do nothing to the car while this happens. If I had known things would take so long (ie, the summer) I would have put different ignition on it and used Dad's VEMS. But it always seemed just around the corner. So then my new ECU comes and shit still ain't right. It turns out to be the same problem I had before with the car (VR polarity) and that helps. But doesn't fix it. So yesterday we troubleshot for 3 hours, searching and searching, thinking physical electrical connection but repeatedly getting cockblocked. When we think we've got it we stop and bleed the brakes, except when we finish they're worse than when we started. Which is bad. Pedal to the floor with mediocre stopping ability. And on top of that, my issue is still there. FInally, after talking to Marc and going through all-things-electrical, I decide to unplug the knock sensors. Another hour and a half in the engine bay to come to that last ditch solution.
And it fucking works. Two connectors.
Not to mention that in the meantime, I have an extremely patient wife with whom I have two wonderful kids. We are building a house, and by that I mean, we are building a house. We're contracting out very little - drywall mud so far. You can imagine that my time at the shop is very limited between work, work on house, extra photo work I do, time on the house we currently live in, and maintaining the other two cars as well. Plus, you know, the kids. The more time this car took, the more easily frustrated I got. Especially when I kept thinking I was there by either replacing something or changing something! By the end of it, any time I spent where no progress happened was a complete waste in my eyes. And there was a lot of that time!
Anyway, thanks all for support or the little jabs here and there because they really do put things in perspective. Giving up certainly would have been easier
