highlander69
Re: Ben's Oceanic PTE5857 AAN 4kq - trigger error demon
Ben,
When I test power and grounds I use a 2 ohm 100 watt resistor in series with my digital amp meter. If batt voltage is approx
12.6 volts engine not running you should have approx 6 amps flowing in a good power or ground circuit if all things are okay.
This test is done with the computer completely out of the circuit and is a good method for checking any 18 to 10 gauge wiring, power and ground circuits.
This method puts the circuit in a dynamic load condition. A good method to determine if the circuit is good or bad. This method has saved my ass so many times I can't recall.
If you don't have a resistor you could also use a headlamp as a quick crude method to put a load on the circuit. Observing the brightness is archaeic, but should be consistent between the circuits.
I hope this helps.
Cheers,
Craig
I hope this helps.
Cheers,
Craig
I like this. How about using a horn instead of a headlamp if you want to piss off the neighbors?
highlander69
Jim, also a great method. I use this method when checking fuel pump circuits on Chevy's and anything else I can think off where I can't see the meter.audifreakjim wrote:I like this. How about using a horn instead of a headlamp if you want to piss off the neighbors?
It really does piss the other mechanics off though.
Cheers,
Craig
Thank you craig! That's a good idea man.
BACK IN BIZZZZNEEEZZZZ! After messing around with grounds (mainly the coil ground), fixing broken wires and such it finally lives! Ultimately I had to go back to the old firmware because I just couldn't get it to run right, so I figured for the heck of it I would try my old one again. BOOM TOWN, it fired right up. I will say this is the first time I have EVER had zero trigger errors all the way through the RPM range. I am not going to lie, this is a MAJOR load off. Now I just need to get the trans in and button back up the wiring.
Also, thanks for all the help guys! I really appreciate it!
VERY, thank you Matt!
What FW were you running before, the newest? 1.29 or something? I wonder what's up with it...
Re: Ben's Oceanic PTE5857 AAN 4kq - Demon gone, now for the
Woohoo! Can't wait to see this thing!
I totally feel your pain on crank trigger problems... :(
chaloux wrote:What FW were you running before, the newest? 1.29 or something? I wonder what's up with it...
I was on 1.1.95 but I updated to 1.2.11. But now I'm back on 1.1.95.
Dude, I can't wait to be driving it down! If everything goes butter smooth, I will have about 5 days of test and tune before the caravan happens.alxdgr8 wrote:Woohoo! Can't wait to see this thing!
awwwww.......you no get ride in 20vt?! weaksauce
LOL I'm glad. Now if only my clutch would get here!AngryTaco wrote:awwwww.......you no get ride in 20vt?! weaksauce
its going to arrive on wednesday
Vids?
Soon my friend. Very soon.chaloux wrote:Vids?
Looks like my clutch is shipping today, so it should* be here by saturday. Otherwise, I will be installing on monday...
Its going to arrive on wednesday as previously stated. I have a track record for being right on these things................................
That would mean everyone that shows up for the caravan is going to help me. LOLAngryTaco wrote:Its going to arrive on wednesday as previously stated. I have a track record for being right on these things................................
I have an appointment at the bar that day
Here ya go man, one of some free revs and LC and the other of just LC.chaloux wrote:Vids?
Give us better links! Gah!!
They are processingpilihp2 wrote:Give us better links! Gah!!
SO MUCH CO2 and H20!
I cant wait to hear this thing tomorrow
Clutch will be at the Post Office by 10am tomorrow, so if all goes well, I should be on the road by tomorrow evening.
And my volvo turbo will be installed tomorrow!!!
