Either route is amazing power.... Let's not forget Nick is already 1-0 against the mighty 07k..... We haven't seen his final form (Queue Dragonball Z music)
amd is the best
Post by amd is the best »
Someone with knowledge on the subject... RS2 intake manifold or not worth it? GO!
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
amd is the best wrote:Someone with knowledge on the subject... RS2 intake manifold or not worth it? GO!
JShadzi wrote:Ok...flow #'s for the 3B...honestly, I was surprised at how bad it actually was. My hypotesis is that flow would degrade further from the inlet, and it was right on...
Total variation of over 12% and 9% from average, #1 cylinder really getting the shaft. Now on average a stock head flows about 200cfm, so the net effect may or may not be so bad. I made over 500whp with this manifold, but I never measured cyl-to-cyl performance, its comforting to see that the manifold I"m now running flows MUCH more consistently from cyl-to-cyl and flows significantly more overall.
FWIW, my new big valve head will outflow even the #5 cylinder of a 3B manifold 8)
JShadzi wrote:OK kids...here ya go.
I'll preface by saying I didn't believe it myself either, but the #'s don't lie. Same flowbench, same procedure as the previous 2. We even went back and ran it again to verify, same exact results...
About 5% less flow across the board than the 3B we tested, make your own conclusions :wtf:
Take it as you will, lots of bickering about how to flow a manifold here http://www.motorgeek.com/viewtopic.php?t=9764
Take the guide shafts out.
Any updates on your fuel pump solution, or still waiting on the 3d printer?
amd is the best
PRY4SNO wrote:Any updates on your fuel pump solution, or still waiting on the 3d printer?
I've got a few printed but I'm not going to install the pumps for a while. I want the new engine to run on the old fuel system for break in so it'll be a but until I know how the double pump setup works out.
Small update, my block now takes the record for most rusty block Jeff has ever seen. After it came out of the hot tank:
After shot blasting:
Journals:
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
Well that's quite the transformation! Looks good Nick, can't freaking wait for vids.
amd is the best
There will be vids-o-plenty. Testing out the Magic Lantern firmware for my Canon's. Should help make the footage a bit higher quality.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
amd is the best wrote:There will be vids-o-plenty. Testing out the Magic Lantern firmware for my Canon's. Should help make the footage a bit higher quality.
I've thought about that firmware, but never really looked into it too much. Or when I was it was write a while ago. I'd love a higher fps setting for the 5d2. I think I will check it out... I need to make something with the 4k too.
amd is the best
Even with ML, I think the 5D2 is limited to 24 or 30fps. My 7D will do 60 but only at 720p which is fine for some slow motion footage.
ML gives some real cool control over audio and tons of other neat tricks.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
In reference to your fb/ig query, here is my car with the fading rings... I think they look pretty good.
amd is the best
Do they fade to white or clear?
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
amd is the best wrote:Do they fade to white or clear?
Clear because its a dot matrix.
amd is the best
Thanks Chris, I'm going to order a set and see what I think. Might end up on the Avant.
Flywheel came!!!
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
gtn116
Post by gtn116 »
Quality photobomb, btw.
2.5TYPE44
Post by 2.5TYPE44 »
Looking good. Man, I sure would like to have one of those. Project is moving along! Can't wait to get feedback.
Lol I bet she loves the car parts in the house. When they're that nice, why not?!
amd is the best
To re-iterate, the main stud kit offered by ARP specific to our 2.2-2.3 20v engines is incorrect. Kit 204-5404.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
Want.
amd is the best
BE JELLY:
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
:) so cool
Nice. Epic styles
amd is the best
Not sure if I want to put them on the wagon or not yet.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
Post by vt10vt »
:drool: I love the look of them on your sedan. I'm thinking of going with a faux rally car look for the 5k, (tastefully) large mud flaps, a couple hellas in front of the grille, flat black hood w/ leather strap and a big 'ol obnoxious reverse fog :D
CassaUrS6
Post by CassaUrS6 »
Stupid ass mud flaps.. smh
