Got the Fronts in this past weekend. Suspension is finally doing good. Besides the higher than stock ride height...
The a1 lower perches are okay if you're in an area that doesn't see much weather. During the install, what, 4 years ago? During the install, no grease or anti seize was added to the sleeve threads or the threads on the locking allen screw. This has caused the allen to seize in the tightened position and the adjustable coil-overs have become non-adjustable coil-overs. So I'm stuck at fender gap of what feels like 4+ inches.
I'm considering drilling out the allen and tapping it for the next size up and running a bolt, as ghetto as that sounds. Needless to say antiseize will be a huge thing when they get replaced or fixed/ghetto rigged.
Also. To show the fun that is using coil-overs with stock front shock topmounts, I'll give you a look at how MESSED UP mine were. well, I'll show you the a1 coil top perches, and then the OEM top mounts after I get a picture of those. Point is. They're effed. Heavily considering some 2bennett plates
