The car I'm looking for would be any color other than green. Not really into black either but would consider it. Tornado red is my main color. Mileage and condition can be whatever as long as it's running and doesn't have significant body damage. Prefer black interior.
My car is a 2001.5 imola yellow 6 speed avant. I am the third owner and bought it from a middle age lady. It has higher miles 182xxx but almost everything has been replaced. List is as follows
F21bt turbos
Ev14 52lb injectors
Clutch net 6 puck disk with rs4 pp
srm 85mm maf housing and intake
Tune still is being worked on as I just upgraded the maf housing currently spiking 19psi and tapering to 16.
034 street density motor mounts.
New Ngk plugs.
Mishmoto tbb
Forge replica diverters
Ecs stainless front brake lines
Fairly new drilled rotors and pads
Fk coilovers (adjusters are pretty seized)
Oz superleggeras 18x8 et35 (bad white paint)
Brand new fuzion uhp tires.
Black leather interior
Podi boost gauge
Piggies pipes with muffler delete (rear o2s coded out
Exterior is good with no dents but lots of small rock chips up front
Interior is perfect.
