:bump:
Spent the day over at the shop today. My goal was to get the engine in for a test fit, which I did. This motor is giving me wood just sitting seeing it in the engine bay. I better make sure I've got plenty of tissues handy for when its ready to start!
I still have a LOT of work to do, starting with welding in some engine mounts.
Looks good in there :-D
Myke helped get the bushing out of the crank
trimmed up the fins on the oil pan prior to install. I still have a bit more trimming to do but clearance isn't bad. I was expecting much worse!
stock pan
after trimming, and bolted to the tranny (I'll take another pic when I pull the engine back out):
Hood closes with plenty of clearance
:woowoo:
Myke thinks I should twin turbo right away. I should be able to make this header work, right Javad?
And just so he doesn't feel left out, here's Myke's brother Dennis (and his father) hooking up a new winch operated plow to his 4 wheeler.
