derracuda wrote:i'm planning on sticking the drain in the boss above where you put yours in, in the block instead of the pan.
looks great though marc!
you cant.
starters in the way.
Toxcheap wrote:HAHAHAHAHAA any other well thought out changes to be different?!!
20v90q wrote:Looks Great! Nice, clean install. Now when are you going to spray some degreaser on those heads/oil pans? :-)
a4kquattro wrote:I also still dont completely get the proper procedure for evening out the tension. I removed the cam pulleys so that they ride freely on the cam nose. I assume you just rock the crank back and forth until the tension evens out? Obviously you cant just rotate the crank around a few times while holding the camshafts fixed as interference would occur..
Nate, how tight was the belt on your stacked gasket setup? Something definitely seems 'wrong'.
gidrew wrote:Marc, What me to see if the Snap On guy has the right tap? He stops by the shop tomorrow. LMK
gidrew wrote:So you just need a 22x2.0 tap? No die or anything? If he has it on the truck, i'll get it, if he has to order it, do you still want it? I know snap-on has them, just dont know if its on my guys truck.
Corey wrote:you're missing the top spring seats :bashtard:
