1995.5 URS6 Holset HY35 on E85
Re: 1995.5 URS6 Holset HY35 on E85
He never had that thing running much out of its efficiency though. 35psi on an hy35 should get it done. I thought 30r is 56mm too though...
loxxrider wrote:He never had that thing running much out of its efficiency though. 35psi on an hy35 should get it done. I thought 30r is 56mm too though...
56 is the trim, but it's a 57/76 comp wheel...
Yeah, I guess you're right. I was also thinking it's the same comp as the hx35 and h1c like I had which was 56/83, but the hy35 is 56/76. Still, at high boost it should make enough power to get close.
LKSi
Post by LKSi »
We will try our best!!
pkw
Post by pkw »
I think that turbo on e85 will be a great feeling turbo for an URS
viewtopic.php?f=11&t=1534
LKSi
Post by LKSi »
pkw wrote:I think that turbo on e85 will be a great feeling turbo for an URS
Me too. I'm most concerned with street manners and I think it will be a nice match for what I'm looking for. . I have or have ordered almost everything for the build. Pics soon.
LKSi
Post by LKSi »
Collector fabrication:
ImageCollector Fabrication 1 by zrwired, on Flickr
ImageCutting collector by zrwired, on Flickr
ImageFinished collector by zrwired, on Flickr
VEMS!
ImageVEMS by zrwired, on Flickr
ImageVEMS2 by zrwired, on Flickr
Holset power
ImageHolset HY35 by zrwired, on Flickr
Also got the intercooler and clutch, just waiting on a few more items
Nice work and parts. I like the jig too
Very nice. Love the manifold fab
Wilford Brimley
Post by Wilford Brimley »
mushasho wrote:I weighted 3923lb with 1/3 tank of gas, full size spare and me in it... I'd love to see a 56mm turbo touch 11's on a UrS car on corn...
I know Nick kissed 11's with a 30r which is a faster spooling 57mm in his much lighter 200tq on e85... but hey, I'm in for results, not hating at all...
Nick weighed ~ 3700lbs at the track. 200lbs comes out to 2 tenths and 2 mph with identical power.
I like getting a little technical :)
Your estimate is only if all other things are equal... power-band, gear ratios (01a vs 01e), tires, air-temp, driving ect... this same conversation on how to get a UrS to break 11's was discussed on the "other" forum in great detail. I'm all for a HY35 build getting it done though...
LKSi
Post by LKSi »
deaner
Post by deaner »
Jeeeeeeealous!
LKSi
Post by LKSi »
deaner wrote:Jeeeeeeealous!
of what?? nothing special here
deaner
Post by deaner »
You're running the exact same setup that I'm planning on running next year. I'm jealous that you're posting pictures of those parts and not me. :D
Wilford Brimley
Those are ballpark figures. Guaranteed you won't lose trap speed with 200lbs less, unless you have to shift into 5th to go the full 1/4 (which is why high HP subarus aren't as fast as they all claim. Most of the 6-speed guys have to shift into 5th at 118, unless they have the 2007 trans)
LKSi
Post by LKSi »
The build starts soon!
amd is the best
Post by amd is the best »
Remember too that the 200 20v 016 has better ratios for big turbo which probably helps slightly in the 1/4 :)
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
LKSi
Post by LKSi »
The guy who tunes it will just have to work really hard to prove himself
