anybody got an early 5k parts car? need a 3.89 type 44 diff
I need a 3.89 rear diffy for an urs customer. etka says MC1 5000q should work. anybody got one of these land yachts rotting in a field and want to sell me a diffy?
Thanks.
deaner
Re: anybody got an early 5k parts car? need a 3.89 type 44
Post by deaner »
I actually may have one in the parts pile. I'll have a look when I get home tonight.
deaner
Post by deaner »
I just went out and looked. I'm fairly certain it's a 3.89 being as it came along with a trans and mc1. Would you know of a definitive way to tell?
What is the 3 letter code by the axle flange? That or the other way to do it is to pull the side cover and divide the number of ring teeth by the number of pinion teeth.
lorge1989
Post by lorge1989 »
I have a 3.89 locker out of a B4 V6 car. It's a long nose which might be a different style than you need.
1988 Audi 90Q 1.8T swap
2003 VW Jetta TDI
1978 GMC High Sierra
2015 Touareg Lux
http://dubsinthebuff.com
Post by vt10vt »
Marc I have one I could bring down next weekend!
elaw
Post by elaw »
Marc wrote:That or the other way to do it is to pull the side cover and divide the number of ring teeth by the number of pinion teeth.
Wow you like doing things the hard way! ;)
Here's all you have to do: lock the diff, then rotate the input flange clockwise a bit to take up any play. Use a sharpie to mark a line across the input flange and case, and one output flange and the case - so you can accurately count turns on the flanges when they're rotated.
Then rotate the input flange clockwise and note how many times you have to turn it to get exactly 1 full turn of the output flange. It should be just under, or just over, 4 turns. If the former it's a 3.89 diff, if the latter it's 4.11.
Eric Law
sorta. in practice differentiating (haha. get it!) between 3.89 and 4.11 this way is harder than it sound. due to gear lash, having to make sure you rotate both flanges at the same time, etc.
vt10vt wrote:Marc I have one I could bring down next weekend!
sss ssss sss SOLD!
thanks.
elaw
Post by elaw »
Marc wrote:sorta. in practice differentiating (haha. get it!) between 3.89 and 4.11 this way is harder than it sound. due to gear lash, having to make sure you rotate both flanges at the same time, etc.
True... there's definitely not much difference between the two ratios.
But you don't have to rotate both output flanges if you can lock the diff. And technically if you were unable to lock the diff, you could hold one output flange in place, then count how many input turns it takes to make the other output flange do 2 revolutions. Although in some cases that would require 3 hands... :wtf:
Eric Law
Post by vt10vt »
sss ssss sss SOLD!
thanks.
Can't beat that for convenience factor! I'll bring her down Saturday, need a matching 016 or 5? I have a pile of those too haha
deaner
Post by deaner »
Heck yeah, that worked out!
Wilford Brimley
Post by Wilford Brimley »
Are those all TORSEN 3.89 transmissions?
Post by vt10vt »
Wilford Brimley wrote:Are those all TORSEN 3.89 transmissions?
200 20v's had a 4:11 but any quattro 5k/20v 200 should be 3.89
My reference: http://www.motorgeek.com/viewtopic.php?f=15&t=8293
Wilford Brimley
I was more referring to your collection. I might pull a nick and start breaking input shafts off
Post by vt10vt »
Wilford Brimley wrote:I was more referring to your collection. I might pull a nick and start breaking input shafts off
Oh gotcha- I have at least 2 torsen 016's I believe and another 2 lockers, all are available!
Wilford Brimley
Are your T44 euro lights still available too?
Post by vt10vt »
Wilford Brimley wrote:Are your T44 euro lights still available too?
Nope sold those a while ago now, sorry!
