I'll just leave these here. As you can see, there a few cosmetic issues but nothing too serious. Drives really well but needs a new driver side control arm (balljoint separated)
Primary purpose of this car is to develop much needed parts for. Prepare to see some cool stuff come out of this one.
Has a chip, spring, aftermarket exhaust manifold, and a few other goodies. Really can't complain for the $2500. Might make a gnarly sleeper out of it...maybe I0v swap it. Who knows
1986 4000cs Turbo Quattro 2001 Dodge Dakota R/T Standard Cab 1990 V8 quattro 1995 urS6
-Hersh Performance and Racing Products- Most orders are being refused until further notice. Please PM
Nice score. Will be interesting to see what you end up doing with it.
Dallastown, PA 1991 Audi 80 quattro (20vt project) 1991 Audi Coupe Quattro (project: my first 20v) 2007 Mitsubishi Raider(Dakota in disguise) 2019 Chevy Cruze RS hatch (wife's little red sporty car)
Well, at least when 20vt shows up in this thread, he probably ment for it to be there!
The front subframe bushings are integrated into the control arm bushings as you'll see. Might be a little more complicated than you'd think to do those ones. The front bushings of the front subframe should be easy though.
Should...
-Phil 87 5ktq - 20vt 91 v8 5spd - Why? 05 S4 - Gone and very much so forgotten 14 TDI Touareg
How do I disable the 15mph limiter for the dif lock?
edit: cut the blue/wht wire
If its anything like the 1991 200, you can just reverse the vacuum tubes under the seat to make it think its open when it really is locked. Don't ask me how I know this...
-2014 Lexus IS350 - SOLD -2015 Yamaha FZ-07 - SOLD -2005 Honda CRF230F - SOLD -2002 Dodge Ram 3500 5.9 Cummins 6 Speed - SOLD -1991 200 20VTQ Avant - VEMS - SOLD -2008 Dodge Ram 2500 - 6.7 Cummins - SOLD
Pulled off the turbo feed line last night and dropped it off at the hydraulic shop this morning. They are cutting it apart and attaching a -6AN fitting to each end. Theyll be making a new braided hose with -6 fittings on each end as well. Im having them extend it about .25" so it will better clear the exhaust manifold.
Should allow me to at least drive it now without worry
