Questions:
Can I try and start it on the turbo map? Is that safe? Or should I search out a different base MAP?
Where do I set my trigger wheel? I've run an ancient Electromotive crank triggered ignition for a few years now and it stated very plainly to align the magnet with the leading edge of the 11th tooth after the -2, but I don't know where to start with the 034. I did see in the GUI a place that looks like where you can enter how many teeth, but again, I'm not sure if that's what that's actually for.
I guess that's all I can come up with right now, I'm not even sure what else to ask at this point.
Thanks in advance,
Garth in Alaska
