Just got home. The car did lovely.
Averaged about 22mpg
Sadly I didnt have full boost, no ac, rough occasional low idle issues, false overheating warning, and no coolant gauge temp. Luckily that mostly all indicates a failed MFTS.
Stopped at my local euro place and picked one up today. Will install it tonight or tomorrow.
After I got home, i replaced the dash speakers with some nicer pioneer ones, installed a gamma deck i had reconditioned, and plugged it in! Now i have 6 fully working speakers. Looks way better than the delta.
Heres some pics from the trip. And one of the stereo too.
Oh, and I installed the v8 rear arm rest that has storage and cup holders.. yay!
And my neverending, current list of things to do
-install mfts
-flush system and put in new coolant
-if mfts doesnt fix ac, fix ac
-loosen all dash and console screws and get the alignment on everything perfect
-finish 3m carbon fiber trim wrap (i really like the one the PO used)
-install rear v8 heated seat controls and wiring
-remove power steering pump and tighten/install intake mani bolts
-remove/rebuild/install power steering rack
-a4 front brake upgrade/throw away ufo's
-swap headlights from my 5k
-swap front end trim from my 5k
-get spare v8 pearl front doors from local yard(if theyre the same.. my doors have some damage on the lower sections)
-remove, polish, reinstall and adjust rear v8 lamps
-install rear muffler (cant take that damn straight pipe!
-install v8 rear window shade and clips
-replace bulbs in switches
