Most of my projects are done on a minimum budget (if any budget at all), and are largely cobbled together of what I have on hand. I 3D print a lot of my non-motor parts like shifter bushings, etc.
Current members of the Cannibal Clown Committee:
1987 Audi 4000 CS Quattro Turbo 20v
- JT Motor converted to Turbocharged
- Running MAC-02V2 from a WX Ur Quattro
- Pressure Limited K24-7000 (limited to 7-10 PSI right now)
- Ur Quattro Intercooler
Future Goals
- Replace head with Turbo 20v Head for Sodium Valves
- Upgrade Pistons and Connecting Rods to allow for more boost
1986 Audi 4000 CS Quattro Turbo 20v
- 3B Motor swapped in with 3B Wiring Harness
- Chipped ECU, running 23-25 PSI on K24-7000
Future Goals
- Roll Cage for Rallying
- Coil on Plug or VEMs conversion
- Replace/Rebuild transmission and rear differential
- Minor lift (1 inch or so)
1990 Audi 90 Quattro 20v
Swap In Progress:
- AAN 20v Turbo motor
- S6 Wiring Harness (conversion to 90q plugs in progress)
1987 Audi 5000 CS Quattro Avant Turbo
- Stock for Now
Future Goals
- Planning to Turbodiesel swap with either a 2.0l 5 Cylinder or a 2.5l AEL TDI
NON-QUATTRO PROJECTS:
1998 Jetta TDI
- 2001 ALH Motor w/ 11mm Injection Punp
- Bosio Nozzles
I'll have pictures up shortly
