I think Ive got it figured out what I’m going to do with the cooling pipes .
For now I’m going to reuse the stock plastic thermostat housing mess and the plastic piece off the back of the head too
. There are universal billet filter housings on the market but I don’t want to reinvent the wheel if I don’t have to.
First piece is kind of self explanatory .
Now for the head outlet to the radiator / expansion tank , I don’t think I want to make that until I get the heater core supply and return done since it will be real close .
So heater core outlet I’m using this piece repurposed , I had to cut and flip a few things but this way it retains the o-ring Seal at the thermostat housing . It looks ugly but when it’s painted and intake manifold is over I don’t think it will be too bad .
At the back of the head . I can use the large ~1.25” outlet to go to the radiator and the expansion tank and then the issue is the smaller 1” fitting is exactly in the wrong direction. I don’t want to make a big loop there so I decided on two options . Either cap it off , or do as tight of a bend as possible . I think possibly reusing this stock hose will get me there , but I’ll have to reduce it down with like a barbed fitting .
So for the other cooling pipe head outlet to radiator , I may have to decide which route is going to be less in the way . I’m thinking option 1 (below)
Option 2
That’s it for now. hopefully soon I’ll do the heater core in and the remaining cooling pipe , finish the turbo outlet to IC and move on
