Volkcar
Re: 600+whp 1990 90Q...fiberglass dashboard(?)
Post by Volkcar »
How much does it weigh? I know that a 90 dash is pretty damn heavy
Zerb
Post by Zerb »
I only had two layers of glass mat on it so far, and it's I'd have to say almost half the weight of a stock dash.
fafwa45
Post by fafwa45 »
Thats awesome
How the ef did you pop that off of the stock dash (which I assume you used as a plug)?
Zerb
Post by Zerb »
thanks man ^^
i should get to work more on it tonight sanding and possibly test fitting in the car.
Zerb
Post by Zerb »
loxxrider wrote:How the ef did you pop that off of the stock dash (which I assume you used as a plug)?
wrapped the entire dash in green painters tape first. then i took some thin fabric and stretched it over the dash and stapled it all over as best i could. resin, glass mat, resin. popped off, very carefully, lol.
speeding-g60
Post by speeding-g60 »
taught by text LOL.
Zerb
Post by Zerb »
not bad for a first timer eh?
OK, I was thinking there would be some hooks in the thing (draft) making it hard to pop. I guess not though. Hopefully you can get a smooth surface off of that with enough sanding and such. I guess it doesn't matter if you are going to cover it. Otherwise, you'd probably have to make a mold from what you have now and lay up inside that.
Zerb
Post by Zerb »
thats honestly the only reason i even attpempted it, knowing damn well that i was going to be flocking it in the end anyway and the surface didnt need to come out butter ass smooth in order to look good.
Here is a sweet composite dash
Zerb
Post by Zerb »
I will def chop the bottom of my dash by the steering wheel like that so that you don't need to take the steering wheel off to fanagle the dash outta the car.
Zerb
Post by Zerb »
chopped the dash a bit, got it to fit. it was a bit wider then i thought it would have ended up being...but it was a mold that came off the outside of a stock dash obviously. any who, it fits, and its getting sanded. then ill have to get to work with the gauges and wiring.
Zerb
Post by Zerb »
so uh, anyone ever resurface a flywheel with a twin disc clutch?
Zerb
Re: 600+whp 1990 90Q...FX700 clutch carnage pics
Post by Zerb »
sanded the dash a bit and started drilling holes for gauges.
Zerb
Post by Zerb »
speeding-g60
i hate to say it but the center section the two gauges arent symmetrical. that lil thing right there would bug the SHIT out of me, and i am only in mine about 2 hrs a year!
but looks good otherwise. get a few coats of HEAVY primer on it.... before flocking it.
Zerb
Post by Zerb »
only thing i wish now looking at the pics is i started the gauges a bit higher up, but oh well. i can put any toggles i need up there now instead of in between the gauges.
HeartlessNomad12
Post by HeartlessNomad12 »
could alwasy cut out a larger hole and mount a plate with the gauges and switches over it so you can get to the wiring and whatever else you have back there in the future..
Zerb
Post by Zerb »
HeartlessNomad12 wrote:could alwasy cut out a larger hole and mount a plate with the gauges and switches over it so you can get to the wiring and whatever else you have back there in the future..
Once I'm done with this there actually won't be any wiring that I need to get to back there anymore. And since I made the dash in fiberglass, I wanted to try and keep it all on one piece.
Zerb
Post by Zerb »
First attempt at painting anything ever. Got some runs in a few tight spots, so I guess some wetsand tomorrow and scuffing then I'll use a jam gun and touch it up. I'm excited to get it back together to be honest, once I saw all the colors together I got pumped.
Zerb
Re: 600+whp 1990 90Q...some engine bay painting, jazz blue.
Post by Zerb »
Zerb
Re: 600+whp 1990 90Q...motor in
Post by Zerb »
bay getting there slowly but surely.
NosBEUI
Re: 600+whp 1990 90Q...fresh engine bay bits going in
Post by NosBEUI »
That Engine bay looks sweet! I like the crazy color scheme you've got going. Are you doing the powder coating yourself?
fasterthenrs2
Post by fasterthenrs2 »
Not my cup of tee, but looks good ;)
