Dan's '93 UrS4
Re: Dan's '93 UrS4
What is the spacer looking piece under your strut?
- ringbearer
Re: Dan's '93 UrS4
It is a spacer for the shorter strut.
Re: Dan's '93 UrS4
But wasn't the strut tube shortened? So how much short of a strut is that?
- ringbearer
Re: Dan's '93 UrS4
Strut tube was not shortened.
- ringbearer
Re: Dan's '93 UrS4
The strut is a koni 8611 1257. About 2 inches shorter. Taking 2 inches out of the housing is too much and the strut is almost all the way extended at a low ride height. So there isn't enough travel. The 8611 1259 is longer and may work but I used a part that has been used before to try and keep.this.aspect of it simple.
Re: Dan's '93 UrS4
What are the benefits of this over the oem style koni insert? If i am thinking right using this shorter strut would reduce the travel by 2 inches.
- ringbearer
Re: Dan's '93 UrS4
It is external double adjustable and valved for higher spring rates than the Sports. There is an 8611-1259 that is longer but I won't need more travel than the 1257 can provide.
I am having Koni make a double external adjustable 80 series for the rear with a coilover sleeve so the upper mount won't be an issue like on all of there coilover race shocks. Not 100% yet but the order is in, I will check back in with them when they reopen after the holidays.
Re: Dan's '93 UrS4
Very nice Dan
And who do you have to know at koni to get them to make you those spiffy special shocks?
Dan
1984 Ur quattro
1987.5 Coupe GT Special Build
1984 Ur quattro
- ringbearer
Re: Dan's '93 UrS4
I explained my situation and they offered to modify the shock they made for this vehicle. All I have to do is pay
Re: Dan's '93 UrS4
That's pretty cool. That possibly gives them another product to market.
Dan
1984 Ur quattro
1984 Ur quattro
- ringbearer
Re: Dan's '93 UrS4
I was inquiring about the 8212 series coilovers and they have to be made, same lead time (8 weeks) as these and about the same price but these will bolt in.
They cost the same as the rusty S4 I bought and parted so I doubt they would sell very many
Re: Dan's '93 UrS4
Very cool indeed, but not the price, that's not cool at all lol.
Dan
1984 Ur quattro
1984 Ur quattro
- ringbearer
Re: Dan's '93 UrS4
Not cool, but I want to do it right and only once!
hopefully
Good shocks/struts are stoopid expensive.
hopefully
- ringbearer
Re: Dan's '93 UrS4 Suspension time!
Custom Koni 80 series rear shocks. Double external adjustable, valved for 500lb springs with a 2.5" threaded coilover sleeve and perch. Should fit and not require a custom top mount like most all of the other good coilover shocks I could find. Need to drill holes up top for adjustment though.
20150130_120001 by ringbearer93, on Flickr
20150130_120001 by ringbearer93, on FlickrRe: Dan's '93 UrS4
Damn I need some of those...
Re: Dan's '93 UrS4
Hey Dan, do you know the part number for the Rs2 rear trap bushings you used? I'm gonna need some soon and I know of others that want to replace that bushing.
- ringbearer
Re: Dan's '93 UrS4
Boy oh boy those shocks looks nice. Well done sir
Dan
1984 Ur quattro
1984 Ur quattro
- ringbearer
Re: Dan's '93 UrS4
Thanks Dan!
They will look even better on the car
- ringbearer
Re: Dan's '93 UrS4
Had some time to actually do something. Got the rear coilovers pretty much sorted out and most of the rear suspension and diff in place. Still waiting on new fasteners for all the torque to yield parts. Nice to have fresh painted parts installed.
20150225_140455 by ringbearer93, on Flickr
20150225_140522 by ringbearer93, on Flickr
20150304_143942 by ringbearer93, on Flickr
20150305_194319 by ringbearer93, on Flickr
20150305_205031 by ringbearer93, on Flickr
Holes in trunk floor for adjustment. They will get cleaned up and plugged.
20150305_205255 by ringbearer93, on Flickr
20150305_205245 by ringbearer93, on Flickr
Exploded views of my coilover setup. Any input is welcome.
20150305_194433 by ringbearer93, on Flickr
20150305_194454 by ringbearer93, on Flickr
Cut bottom of upper mount so the spring tophat would fit better.
20150305_193440 by ringbearer93, on Flickr
20150305_193458 by ringbearer93, on Flickr
20150305_193505 by ringbearer93, on Flickr
20150305_193509 by ringbearer93, on Flickr
20150305_193514 by ringbearer93, on Flickr
20150305_194356 by ringbearer93, on Flickr
20150305_205031 by ringbearer93, on FlickrHoles in trunk floor for adjustment. They will get cleaned up and plugged.
20150305_205245 by ringbearer93, on FlickrExploded views of my coilover setup. Any input is welcome.
20150305_194454 by ringbearer93, on FlickrCut bottom of upper mount so the spring tophat would fit better.
20150305_194356 by ringbearer93, on Flickr- ringbearer
Re: Dan's '93 UrS4
You actually have that backwards, I looked over your posts and that seemed like a good idea so I copied it. Did you use the thick OE washer on the shock shaft that the top hat sits on ?
Re: Dan's '93 UrS4
Ah, I didn't remember posting about it
You don't need that thick washer unless the diameter of your shock is small enough to fit through the top hat. Although, it does create a bit larger seating surface for the soft aluminum
Re: Dan's '93 UrS4
I didn't do that to mine when I had my rears apart in the essence of time and having a dead grinder, but I'll be doing that next time I have it apart.
Lookin real good dude!
- ringbearer
Re: Dan's '93 UrS4
I made a collar to keep the top hat centered as it is bigger than the shaft but not big enough to go over the step. I will leave the washer for more surface area. You had the upper mount info in a QW post.
Thanks Phil! That trans will come out someday lol, I'll bring it to Dans for the drive if you want.
