Re: 01E swap into B3
Posted: Wed Jun 27, 2018 9:27 pm
Yes you can use the b3 slave. I'm currently using the metal b4 one in my fyf 01e. I just unbolted it and let it hang until I reinstalled the transmission, no bleeding that way.
It has a different fitting for the hydraulic line. At least what I received does.quattrobros wrote:can you not use a b5 slave?
Slaves are the same 01A/01E but I'd look for a metal 01E version if you have to replace it anyway.Grillage wrote:What slave cylinder do I want to use? Can I use the b4 01a slave?
Is it just because of the hard line fitting? Everything B5 (01A and 01E) is the same slave, but I guess the B3/B4 chassis might use a different kind of fitting. Other than that there literally can't be any differences dimension ways; they're the same trans as a B5 after all.Grillage wrote:I ordered another 95 90Q slave - the B5 S4 slave I bought is definitely different and getting returned:
https://www.autohausaz.com/pn/SH6142
the german wrote:correct. B5 and later is typically plastic and uses a different style of fitting. B3/B4 are typically metal and use an M10x1 threaded fitting.
