Spent some time today to continue cleaning the engine bay. Gonna hit it with a fresh coat of pearl before the 3B goes in.
Thanks! The white shows everything.Afterthought wrote:Looks excellent , not easy to clean all that grime out
I know. Need to check with them to see how often they have that deal. I’d like to go back and get a few more things. I’ve already sold the hood conversion parts.Afterthought wrote:Dude I still can’t get over how good a deal you got on all those parts . I would be in heaven if I found pearl b4 front end and fenders.
Thanks. That’s a tough one. I’ve tried to clean most everything I’ve touched, but the underside has not received the same treatment. I think I might break out the power washer again before I se it on the ground. It worked pretty well on the wheel wells.Afterthought wrote:Engine bay looks great. When you get the engine in this will really be worth all the effort . Will look amazing .
Only Issue is now you have to take everything to this level of cleanliness .
Thanks. Yeah, I’ve been really tempted to convert to vacuum assist, but I had Dave Kase rebuild my bomb last year and it’s been working well (knock on wood).Afterthought wrote:Engine bay looks so good .
If you have any plans to change anything on the booster or steering rack do it now , ha
Thanks. Next is to reassemble everything. I’m really pushing to have it running by early Summer.FFF wrote:Engine bay looks great! What’s next?
I have to do that regularly myself. Would be lost sometimes without them.FFF wrote:Be awesome if you get it on the road this summer.
It's been so long since I pulled my car apart I'd have to go back through pictures to even recall the setup!
Thanks Forrest.FFF wrote:Coming together nicely.
Thanks. I am trying hard to keep it clean and tidy. I like the idea of being able to jump it (if needed) from the front or rear and not be worried about which way it’s parked in the garage.themagellan wrote:Everything looks amazing - great idea with the jump post, now that you added it hope you never need to use it
Thanks! I was planning to trim that post down after I get the transmission ground cable built and connected. To start with, it’ll be the stock turbo, EM, and a modified 3B down pipe.Afterthought wrote:that wiring looks great and man the engine bay looks so clean , and the wheel wells .
I don’t know if you’re going stock or what exactly you’re doing for turbo and exhaust but the only one thing to check is downpipe clearance with that stud.
