I know the search button...I've been searching here and that other site for 3 days...I've seen you can use a 200 or 5k donor. I'm wondering what you can do to make an urs 5spd work, since I have one sitting here...it seems v8s4 trans mounts will work? Or there was a euro v8q 01e 5spd, but what I really need to know is has anyone done this swap? If so what's the recipe? Axles, prop shaft, I think I can figure the rest out...
Thanks for any links or help, I really like this car but fear the transmission is going.
O1E in a V8Q?
Re: O1E in a V8Q?
well they exist in factory form. so the real question is how fast do you want to get this done. basically for extra $$$, you could ship in trans mounts, linkage, front axles, driveshaft, interior manual shift boot area stuff, pedal cluster, master and slave cyl.
and a 10bolt flywheel, clutch, PP etc
are you starting with an autobox or a 016 5speed?
that said im SURE there are a lot of parts in the USA that you could use.
if you can get the car partially torn down and take a bunch of measurements, im sure we can solve the driveshaft and axle parts, with swapped parts or potentially, spacers
linkage can be made (hybridized) w/o issue, urS stuff can prob be modded to dropin
t44 pedal cluster might work with some massaging
itll be a lot easier to ship mounts, and interior bits vs a driveshaft and axles/linkage etc
all in all, it really depends on how long you can take the car off the road, less time = spensive, long time = a lot cheaper
O1E in a V8Q?
Starting with an auto. Shorter = better... Hopefully the auto will hold up until I get the 4k road worthy again.
Re: O1E in a V8Q?
scubagli wrote:Starting with an auto. Shorter = better... Hopefully the auto will hold up until I get the 4k road worthy again.
I have a set of brand new never mounted factory V8Q transmounts. Makes it a bolt in affair. You can get most of the parts from an Urs4 like driveshaft, and shift linkage. You'll also need to weld the top of the tunnel for the shifter base. 200 20vt axles with the Iroz spaver and you should have everything ready. IIRC the mounts can be order new still or look on ebay.de there have been a few sets.
HTH's
91 V8 Quattro 5-speed
91 200 20vt Avant
90 Coupe Quattro 7At
91 Coupe Quattro V8 project (long term)
81 VW Caddy
09 VW Rabbit TDI AWD project
91 200 20vt Avant
81 VW Caddy
Re: O1E in a V8Q?
v8coupe wrote:scubagli wrote:Starting with an auto. Shorter = better... Hopefully the auto will hold up until I get the 4k road worthy again.
HTH's
Thanks for the info!
Re: O1E in a V8Q?
I'm doing a 5-speed swap in a couple months on mine but I'm using a 200 20v 016 trans
Re: O1E in a V8Q?
AngryTaco wrote:I'm doing a 5-speed swap in a couple months on mine but I'm using a 200 20v 016 trans
which is the best and easiest route to going manual
