Calibrating map sensor at elevation.
So i'm having some weird map sensor issues and I'd like to recalibrate it to remove that variable, but I'm at almost 5000 feet elevation here. Do I go off the normal calibration of trying to get the map to read 101 at engine off or should I adjust depending on my elevation because pressure is lower up here?
Something I've always wondered but never bothered to figure out....
bradyzq
Re: Calibrating map sensor at elevation.
Post by bradyzq »
Umm, wouldn't suggest that.
Fix the issue.
Can you make load equal to MAP/baro?
Cheers, Brady
72 240Z 123whp
www.dynodoc.ca
Mine always read <100 @5280'. I'd leave it.
