URS4 rear sway bar on a type 44?
Wilford Brimley
Post by Wilford Brimley »
I know it can (and has) been done, I'm just curious if there is a comprehensive write-up on it. I'm also curious if the larger front 1992-spec swaybar is a direct swap as well.
Re: URS4 rear sway bar on a type 44?
The front sway isn't, but you can get a thicker v8 one (special option on the v8).
Wilford Brimley
any input on doing the rear swap?
Not from me, but I'd like to know more as well.
NewFlesh
Post by NewFlesh »
034 lists the Apikol rear sway as fitting v8s and 200s...
http://store.034motorsport.com/rear-sway-bar-kit-c4-s4-s6-and-v8-quattro.html
It will work but you will need everything required to mount it. Brackets, etc.
Wilford Brimley
pilihp2 wrote:It will work but you will need everything required to mount it. Brackets, etc.
I have an entire donor car.
amd is the best
Post by amd is the best »
I plan on buying one for my Avant. I have one here too ready to be installed on a friends URS4. I should just test it on the Avant.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
stt
Post by stt »
I've been running the Apikol\Hap bar on my 200 for a few years. I also run the bar on my UrS4. I may still have my old UrS4 bar too. Coupled with the 2B coilovers, it was a great mod for my 200. Sorry no write-up.
Running a front one, wouldn't help much. The rear ones would help turn in a massive amount!
Apikol sells them, and if you specify you have a 200 20v, they'll give you the pieces to drill to make it fit into place. Always something I've wanted to put onto my car as well.
