Tail light lens repair
I have a pretty good crack in a tail light lens. Anyone have a good mothod of repairing this? This crack goes from top to bottom, and the only thing holding it together is the back plate. I have found some pigmented epoxy designed for tail lights, but was looking for some BTDT.
Thanks
varia
Re: Tail light lens repair
Post by varia »
¯\_(ツ)_/¯
project 2226
It looks like that worked quite well. Do you happen to know the OP of that thread? Hi would love to see how well it looks now after some time has passed with it in the UV rays of the sun. I would hate to see it spider out from exposure.
I'll PM you his email.
I tried the solvent welding, and it worked pretty well. You can still see the crack, but I could only ask so much.
ImageThis is how the panel looks after wet sanding with 2000 grit paper.
Anyone have some tips on a good plastic polish to use? This will be done by hand, as I really don't want to break it again.
Thanks
Well with some compounding and liquid polish, this is the end result. Sorry, the best lighting in my apartment is in my bathroom...
32vquattro
Post by 32vquattro »
DE80q wrote:Well with some compounding and liquid polish, this is the end result. Sorry, the best lighting in my apartment is in my bathroom...
That came out looking like new, great job restoring that lense!
Thanks, but i should have posted an uodate.
Now that it has been out in the sun, rain, and dirt, the crack has popped out visably. The next try will be to grind it out and lay in some pigmented epoxy. The hard part will be to match the color.
lorge1989
Post by lorge1989 »
Why don't you spray clear coat on it after you fix the repair?
I'm thinking, fix the crack, wetsand down to 800 or so maybe even finer, then spray an automotive clear coat then buff.
1988 Audi 90Q 1.8T swap
2003 VW Jetta TDI
1978 GMC High Sierra
2015 Touareg Lux
http://dubsinthebuff.com
The problem was the epoxy that I used to fill in the rest of the crack has turned a milky color. It was supposed to be an outdoor UV safe clear epoxy, but I guess it wasn't quite as good as I had hoped.
I may end up pulling it and listing it for sale. I like how t looks, but not enough to try my hand at modifying a bumper.
Came out amazing nice save
