Anybody need a 7A bottom end?
The coupe I bought had the timing belt pop and the head was scrapped by a shop. The bottom end is currently complete, but the oil pan is not available. Does anyone have any need of the parts from the bottom end? I'm getting another complete 7A to replace it with, and would hate to scrap these parts when someone might be able to use them. In full disclosure, the Odom. reads around 203k, the car has been sitting for nearly 5 years, and the head was removed about 1 year ago. The PO did saran wrap the deck, so that should have helped.
If you can use any of these parts, let me know.
Thanks for looking.
Re: Anybody need a 7A bottom end?
Might be worthwhile to keep the piston oil squirters if the rest goes to scrap. Not sure how often they fail but can't see them getting easier to find as time goes on.
I grabbed the ones from my old 20vt block before it left as well. I didn't know the 7A block had squirters.
It's out now... Let me know if you need anything. It will be scrapped in about 2 weeks.
