VEMS serial communication problems
to start im using an econoseal ECU with a jumper harness i made to make it PNP with my AAN harness. i originally created a motronic bench harness to test ECU's after i did modifications without having a car as well. so i hooked all this up to my bench setup along with the a USB to serial converter to my tower in my work bench and the ECU connects with VEMStune with no problems. my problem is when i put it in my car connected to the factory engine harness it cannot connect with my either of my laptops. i even tested it with my laptops on the bench harness and i get no communication but as soon as i hook it to the tower it picks up the ECU right away. im using the same USB to serial converter on every case and i have all 3 computers configured to use the same com port for the USB serial converter. whats going on here? is my ECU locked to a single PC? the tower was the first PC i hooked it to too.
84 4000S quattro-AAN swapped
83 UR quattro
95 URS6 avant
95 URS6 sedan
90 90 sedan-AAN swapped
91 200 20V turbo
92 GTI VR6
92 GTI G60 X-flow turbo
86 16V jetta coupe
83 UR quattro
95 URS6 avant
95 URS6 sedan
91 200 20V turbo
92 GTI VR6
86 16V jetta coupe
Re: VEMS serial communication problems
What operating systems? Drivers installed correctly? I just picked up a new small laptop on windows 8 and had to buy a new usb-serial adapter cable because my old one that worked with everything up to windows 7 doesn't with windows 8. here's the one I picked up:
http://www.amazon.ca/gp/product/B00425S ... UTF8&psc=1
actually i solved it after posting this. i forgot to add the ground from pin 5 of the serial port to the ECU. for some odd reason it would work fine with the tower but not my laptops.
83 UR quattro
95 URS6 avant
95 URS6 sedan
91 200 20V turbo
92 GTI VR6
86 16V jetta coupe
83 UR quattro
95 URS6 avant
95 URS6 sedan
91 200 20V turbo
92 GTI VR6
86 16V jetta coupe
