Easy way to swap rear diff bushing without press?
Re: 1990 CQ- LED interior light-too cold to paint-maybe mond
I'm a bit spasmodic...
I tend to get like this when I'm heavy on narcotics. The cold weather is really getting to me lately. Ill reread again. Lol
SapperMike
Spas! So were not staying in Dallas Saturday BTW, were gonna unpack everything and drive up Sunday morning. Ill swing by later if I have time, were gonna be coming out this week to clean the house up a bit
Sent from my LT28at using Tapatalk 2
sounds good to me! Have fun unpacking! Painting the car today.
OKAY, so paint for the car is going to cost me more than i have at the moment, so PRIMER is going to shot first then next month i will resand and paint then.
Nice day today.
unless you are on the east coast.
Be safe out there you guys.
Nice day today.
Mentosman42
Take it slow and do it right!
Just like the bondo was the wrong thing to do and your fixing it the adapters will just be more wasted money. There are options as far as 5 lug swaps go. Bite the bullet and do it when you can afford it. I go through this with my friends all the time because they want to jump the gun and buy the "cheap" stuff so they can get what they want right away and within a week you hear "I should have done it the right way...."
Building a car takes YEARS no matter who you are. There are people here that might get them together in a couple months or a year but they have been saving money and gathering parts for years. Dont get impatient.
And yes the weather over here sucks right now. Always interesting when you see massive oak tree trunks swaying back and forth(taking about 2+ feet in diameter).
95.5 ur-S6
83 20vt urQ
83 20vt urQ
I am having the same issue here is PA. I have 5 large tree outside of my apartments balcony, watching them sway is a little nerve racking. I hope you and yours are safe through this.Mentosman42 wrote:And yes the weather over here sucks right now. Always interesting when you see massive oak tree trunks swaying back and forth(taking about 2+ feet in diameter).
Mentosman42
yeah no problems here, we are at high ground.
I live on a peninsula a 1/4 mile from the ocean but we have 20ft high cliffs and then our house is another 20ft above that.
95.5 ur-S6
83 20vt urQ
83 20vt urQ
Very nice.
No, I was saying that the offset on the Ur hubs needed massaging. You can run G60s with 5-lug, IIRC, you'll just have to redrill the brake rotors.Kuma85 wrote:So you are saying i cant just swap out the hubs? i HAVE to swap the brakes out? That sounds like no Bueno...
I think fifteen52 makes 4x108-->5x112 adapters. Should be able to find something thru them or adaptec speedware.
Ima check it out
Okay, going to primer the car today, but gonna hold on paint.
Paint is more spensive than i had the dough for...
anyways, the plug thats in the hatch will get refilled with fiberglass when i repaint.
the primer will do fine for the Car show.
im also going to swap out the passenger side door panel as its all NASTY.
Plastidipped the wheels
And did my mirrors
And did my mirrors
90quattrocoupe
Those wheels and mirrors came out nice.
Greg W.
Greg W.
yeah i think so too.
I reallly like how the mirrors came out. They look WAY better than before.
i MIGHT do the door handles.
SapperMike
It was funny when he did the wheels. He was like "they look so much better!" And I was like yea, only cuz you cant see all the scratches and imperfections now lol.
zarati
I dont get this. I thought you just ran UR-S4 Rotors when you did that swap. Offset is about the same as the CQ Rotors.PRY4SNO wrote:No, I was saying that the offset on the Ur hubs needed massaging. You can run G60s with 5-lug, IIRC, you'll just have to redrill the brake rotors.
zarati wrote:I dont get this. I thought you just ran UR-S4 Rotors when you did that swap. Offset is about the same as the CQ Rotors.PRY4SNO wrote:No, I was saying that the offset on the Ur hubs needed massaging. You can run G60s with 5-lug, IIRC, you'll just have to redrill the brake rotors.
Not sure what brakes you're thinking of... maybe they work well for G60 rotors (stock on Cq & UrS4) but I went with D2S8 rotors & 986BoxsterS calipers. When I did my swap a 3mm hub:rotor spacer was required, and the inner face of the rotor had to be spun down a bit to clear the tie rod end. Details are in my build thread (link in sig).
RhodyVW
Re: 1990 CQ- Paint on Friday-Broken front Subframe)-;
you can get those in 4x108, I have a set in my garageKuma85 wrote:http://www.latemodelrestoration.com/item/LRS-1007SCM/1994-04-Mustang-Silver-Sc-Style-Wheel-17X9" onclick="window.open(this.href);return false;
i like these i think.
Shaving the lower doors and the rear lower body trim.
pics to follow completion.
Re: 1990 CQ- Shaving the lower door trim- pics to come!
more work was finished to the CQ! the trim that is always falling off on the bottoms of the doors and behind the doors is replaced with bondo.
Down to hand sanding and it looks MUCH better.
still need to work on the doors some, but it looks much better than it did with the missing trim.
teaser pic
teaser pic
frostyflax17
- Contact:
Needs lotsa sanding, should look good after some work and paint.
Cory
11 Touareg TDI - Daily
91 CQ - Lifted Rallyx Mudder
90 CQ - 3.0T Rombotis
90 CQ - Wannabe S2
91 200 3b - restore and sell
90 CQ - Wannabe S2
Yes LOTS of sanding. but overall so far, i am very happy with having NO TRIM.
That one nice part with the sedan. Much easier to delete lower trim.
