here's what i did.... and this is via Martin Pajak's instructions put up all over, but i'll do it once again since tons of people are always asking
i used the stock rear struts, rotors, calipers, carriers, and bearings. the only thing different are the hubs, which are from a 5ktq front strut. appearantly the front and rear hubs are the same on a 5ktq, so if you have one to pick them from, don't just grab fronts, rears will work too
step one, remove strut
step two, remove rear hub and wheel bearing
key ingredients...
step 3, press it all back together as if you were replacing the wheel bearing only, but put the 5ktq hub in place of the 4kq rear, and you'll end up with a strut like this
dang!, someone stole mah wheel!
install new 5lug hub equipped strut
redrill the holes on the stock rotor for 5x112
[img]i%20didn't%20take%20a%20pic%20of%20that%20cause%20i%20forgotted[/img]
install test wheel with too large aspect ratio tire
viola'! man, those rims look at good on there as i thought they would. i'm keeping my eyes open for a set of fuchs possibly.... cause these cars look sweet with em' 8)
