Question torque on ARP cylinder head studs
Looking at retorquing my ARP cylinder head bolts. Information about that is misleading. Some do, some don't.
Mine where torqued once at 80lbs/ft. Should I be concerned ?
- amd is the best
Re: Question torque on ARP cylinder head studs
da_trem wrote:Looking at retorquing my ARP cylinder head bolts. Information about that is misleading. Some do, some don't.
Which kit do you have? If undercut (ARP 204-4704) retorquing is not necessary as they are technically stretch studs, kind of like OEM. If non-undercut, then retorquing may be a necessity.
Undercut set. No retorque then.
Thanks a lot!
Dave
Thanks a lot!
Dave
No personal experience here (my 3B is stock, head bolt-wise), but I remember someone posting about needing washers under the nut to help spread the load and avoid digging in to the head. I think it was chaloux who wrote about this.
Cheers, Brady
72 240Z 123whp
www.dynodoc.ca
72 240Z 123whp
www.dynodoc.ca
boost_addict
it always good to check or re-torque any head studs undercut or not. I torque mine to 85 in steps. 50, 70, 85
91 VEMS CQ vr6 6766 o1e s2.
01 GTI vr6 vems 6262
01 2500 Cummins hx40. Tow Rig, vems round 80psi
bradyzq wrote:No personal experience here (my 3B is stock, head bolt-wise), but I remember someone posting about needing washers under the nut to help spread the load and avoid digging in to the head. I think it was chaloux who wrote about this.
The ARP kits come with washers. It's the used sets that dont
boost_addict wrote:it always good to check or re-torque any head studs undercut or not. I torque mine to 85 in steps. 50, 70, 85
x2
AngryTaco wrote:bradyzq wrote:No personal experience here (my 3B is stock, head bolt-wise), but I remember someone posting about needing washers under the nut to help spread the load and avoid digging in to the head. I think it was chaloux who wrote about this.
Yes, I am aware of that.
BIGGER washers needed to avoid cutting into the head by not distributing the load enough.
Cheers, Brady
72 240Z 123whp
www.dynodoc.ca
72 240Z 123whp
www.dynodoc.ca
With the new torque spec after people lifted heads.
Oh well, i'll recheck these anyways since I'm in need of a new timing chain. Cams are already off. I'll come back to you with results as retorquing was necessary or not.
As for the supplied washers in the ARP kit, I not using these. I've ordered HD ones from Thuppu on S2 forum.
If anyone needs ARP head washers, just let me know.
Thuppu's HD head washers:
Did my timing chain last night. Rechecked torque of the head studs nuts. They were all within specs, the undercut set I have haven't loosened a bit.
Those washers are sexy. Also...I always retorque, undercut or not. 07k wont take the bigger washers because ARP made them proper the first time. ;-)
