Josh wrote:Hi marc
I ripped out ABS on my coupe quattro and cut the wires and then realized that the rear diff wiring is within the ABS harness. If I install the v8 combo rear diff inside my coupe quattro diff I will not need the wiring and the vacuum setup anymore correct?
Thanks
Josh
correct.
Josh
Post by Josh »
sweet, sy of relief :-D
Finished rebuilding the driveshaft, put everything back together, and drove the car in all 7 gears with the car on jack stands to verify everything. so far, so good. Should be able to put the car on the ground tomorrow.. but..
I think I may need custom tie rods. Just eye-balling the wheels straight I'm out of adjustment range on the passenger side tie rod :(
a_CQ
Post by a_CQ »
Just FYI...on the Coupe...when front toe is '0' and you have -- camber your wheels will look like toe'd out....get it on the rack and have them check before you do anything...good luck!
HT Motorsport
Post by HT Motorsport »
a4kquattro wrote:Finished rebuilding the driveshaft, put everything back together, and drove the car in all 7 gears with the car on jack stands to verify everything. so far, so good. Should be able to put the car on the ground tomorrow.. but..
Cool,
Time to call rod end supply and online metals to get the parts you need for some nice chromoly ones with spherical rod ends :)
H
Cool,
H
H! Good to hear from you. Hope Australia is treating you well, I still haven't seen any pics of what you've been working on :wtf:
a_CQ
Post by a_CQ »
Marc, any alignment updates?
a_CQ wrote:Marc, any alignment updates?
haven't taken it to the shop yet, probably tomorrow. I'll most likely put it on the ground tonight.
I think I need to adjust my spring perches ;)
Wizard-of-OD
Post by Wizard-of-OD »
:o
Mark that looks really good!
Those are 17"?
HT Motorsport
a4kquattro wrote:I think I need to adjust my spring perches ;)
Na, Its perfect :)
GTIVR62801
Post by GTIVR62801 »
Someone cue the famous song by War now....thats one hell of a lowrider!
WAUG0806
Post by WAUG0806 »
"put it on the ground "
on the ground indeed! :wink: 8)
Such a good looking coupe Marc! I want a V8 every time I see your engine bay!
subvertdesign
Post by subvertdesign »
Nice! The red valve covers make it look extra bitchin.
RSCoupe
Post by RSCoupe »
Audilard wrote:Such a good looking coupe Marc! I want a V8 every time I see your engine bay!
:stupid: :woowoo:
Thanks guys, I dig it too :)
I think I might give 034 a call, I know they make custom tie rod assemblies for a reasonable price so it would save me a bunch of time ordering the rod ends and making one myself. I'm thinking stock length - 3/8" should do.
Hey, Marc. When are you going to make and sell V8 engine mounts to fit the Coupe engine bay??? :-D
Audilard wrote:Hey, Marc. When are you going to make and sell V8 engine mounts to fit the Coupe engine bay??? :-D
heh, my car is not a good test mule, since I opted to cut the arms off the body. If I was to do the project over again (which, I wont :) ) I definitely would have made new engine arms to fit the stock locations.
I'll have to "suggest" it to 034 then. :wink:
s2 on the way
Post by s2 on the way »
:drool: sittin mighty nice, as if it wasnt' already perfect :D
I've always liked the s4 wheels on the coupes
90quattrocoupe
Post by 90quattrocoupe »
Audilard wrote:I'll have to "suggest" it to 034 then. :wink:
034 could probably could supply you with a set, as they made some for my car.
Greg W.
a_CQ
Post by a_CQ »
Looks great! but, you'll need to raise it a bit....
How does the left wheel look toe-wise? that right one looks ok.
dspl1236
Post by dspl1236 »
drop is sweet...nice lookin wheels there...makes me want to do a 5-lug
those would be sick on a black cq..
Josh
Post by Josh »
get in line... I've been waiting. :D
