86 Alpine white 4000 commemorative , AAN / 01E / VEMS
Post by Afterthought »
OK so for a while I have been looking around for a new driver... Been searching for a long time for a clean white 4000. Finally saw one pop up, my craigslist alert app failed me but luckily got a tip off :) I have been working every day but emailed the guy 3 times, took a day off and got someone to cover me and arranged a trailer for the morning... The car was too clean to not take a chance on. Finally got a hold of the guy at 7AM and was down in Seattle within 2 hrs with a trailer.
PO was an audi enthusiast and purchased from the original owner in California. The car was given to his brother, a car guy didn't know much about german cars. He tried to sell it, someone took it on a test drive and was gone for two hours+ and came back and the car wouldn't run. He did a tune up done on it and spent about $800 to get it to run. Let it sit since last sept. and now it will start, but it only runs until it warms up then appears to starve for fuel or completely die.
Some details on the car:
1986 Audi 40000 Commemorative Edition with the red leather.
All service records since new, clean carfax.
164,335 miles. Odometer still works, all windows work, sunroof works, Etc.
Extremely clean survivor, inside and out - clear peeling on hood though.
Edit: 1/28/17 Current build details
Engine:
AAN (stock internals)
440CC Injectors
034 Fuel rail
Aeromotive FP Regulator
stock 3B intake
URQ intercooler
RS2 Exhaust manifold
3" Stainless TIG exhaust, Magnaflow muffler
Factory AAN Harness
Bosch Wideband 02
VEMS Plug and play ECU
Upgraded oil cooler, custom lines
Drivetrain:
RS2 replica mounts (unknown brand)
01E "Wide first" 5-Speed
URS interior parts to retain reverse lockout
034 Short shift kit
Ground Control adjustable coilovers
Koni Struts
16 ATS Type-10 wheels
Maintenance:
Relocated battery to trunk 9/2016
New battery 9/2016
Fuel Filter 9/2016
New Tires 9/2016
New front Ball joints 12/2016
New rear Ball joints 12/2016
New front tie rod ends 12/2016
New front wheel bearings 1/2017
New alternator brushes 1/2017
Oil pan gasket 1/2017
Brake fluid flush 1/2017
Trans Mounts replaced 1/2017
Engine bay
Re: 86 Alpine white 4000 Commemorative edition
Update 8/27
My goals for the 4000: 20VT, 01E 5 or 6 speed, VEMS
Well I don't know how this worked out so well but as luck would have it, I found a "Parts Car" that has everything I have wanted for my white 4K. Found it just over the border from me in BC.
The only problem? I don't know if I have the heart to take it apart. This car has a special significance to me because it has been passed all over Washington and two of my good friends owned it.
It was 20vt with stock URQ CIS and very clean inside and out but never ran right and has now been morphed into a 20vt.
The conversion is done very well with a front mount radiator and dual fans which I really like. It has developed some cancer and I need to figure out whether it can be repaired or not. If there's any chance its worth saving I wont scrap the car.
Build details:
86 4000 Commemorative edition
Engine: AAN (stock internals), Factory AAN harness
Turbo: Stock
Exhaust Manifold: RS2
ECU: VEMS PnP ECU
Injectors: 440CC
Trans: 01E w. RS2 style mounts and 30mm spacer on left side. urs4/s6 linkage arm/016 linkage
Axles: ??
Suspension: Ground control coilovers (spring rates 340F 380R) , Koni inserts
Engine mounts Energy Suspension 1044
Subframe bushings , new factory
Awaiting install: DM Forged rods, ARP Head studs,
Still need : Exhaust manifold, Turbo
Last edited by Afterthought on Fri Jan 27, 2017 12:40 am, edited 4 times in total.
http://forums.quattroworld.com/s4s6/thr ... tml#334270
aan for sale in San Jose kinda far but worth the clicks
Nice buy by the way!
ringbearer wrote:http://forums.quattroworld.com/s4s6/threads/30161.phtml#334270
I saw that on ebay. wouldn't be too hard to ship...
the german
Post by the german »
Nice! Glad it went to a good home
Kirk
1990 ABZ CQ
1990 lifted CQ
2005 S4 6MT
Post by AudiSport4000 »
Yeah, glad to see this CE find a nice home. Let me know if you need any red leather bits! I contemplated bringing this one back to IN to be a brother with my graphite CE ;)
I bought 7A cams and AAN tools from the seller a few years ago, he was straight up, no BS. I'd still expect the same.
I did email him about it. I got a quote and it would be $300 to ship.
I did replace the fuel filter yesterday and ran some seafoam through the 4000. Checked the ISV and cleaned it but it was really clean to start with.
Its going through fuel pretty fast and has a hesitation on light accel and low RPM's. Almost feels like it's running rich. I am going to see if I have another coolant temp sender and work towards testing or swapping that out.
ARay
Post by ARay »
Thats one nice looking 4000 you got there. I wish mine looked that good. Im strongly considering parting mine out. PM me if your interested in the AAN and vems.
1986 Audi 4000q AAN 01E swap VEMS coilovers.......SOLD
1997 Subaru wrx sti type r
1984 Toyota ext cab 4x4 38" swampers dual tcases w/ 4.7 gears full float rear axle....................
1998 Toyota 4runner sr5 3.4v6 4x4 w/factory elocker
ARay wrote:Thats one nice looking 4000 you got there. I wish mine looked that good. Im strongly considering parting mine out. PM me if your interested in the AAN and vems.
Thanks ARay.. got er home :)
ARay
Post by ARay »
I'm happy to see it go to a good home. I'll let you know if I end up finding anymore 4000 parts when the shipping containers get unpacked.
So worked on the CE a bit yesterday. On the side of the road.
I drove it around for around 40 miles after I got it and it ran rough but never stranded me. Yesterday I made it about 3 blocks and she died and would not restart. Spent quite some time looking for any vacuum leaks or anything related to that but the way that it died was almost like a complete loss of power. Today I will be doing a good cleaning of everything related to the battery grounds.
I think the issue of the rough running is possibly separate. It may be related to the coolant temp sender, or it is worth a try but the part I ordered was wrong. Looks like I need to do some better searching.
ARay
Post by ARay »
Check the ground wires on the side of the intake manifold. They can corrode and break at the ring crimp. Pull the connector off the ecu temp sensor while its running. If it starts running worse (really rich) then the sensor and related wiring most likely aren't the issue.
I found one bad ground so will clean that up. The block to the battery negative was disconnected. Also found a weird brass jumper wire under the fuel pump relay and will try a different one of those.
Havent found any change from unplugging the temp sender while the car is running.
Never did figure it out yesterday spent almost all day working on the coupe and making room in the shop.
Re: 86 Alpine white 4000's
On the turbo 4K I Did get the proper USB->Serial cord and get the VEMS hooked up to my laptop. did a little driving around.
It is running great at idle and part throttle but under boost everything is off so I babied it around for a bit.
Id be interested to hear your opinions from the seasoned VEMS tuners, this tune is for a car with a different fuel pump, same injectors, different turbo.
My guess would be with the boost being so far off it would be better to start with a base tune that is for stock turbo? Any thoughts? Also does anyone have a VEMS map for stock turbo AAN 440CC injectors?
For the stock 4K I can not get it to run properly. It will die as soon as it is at full operating temp. I haven't devoted much time to it. This morning I finally invested in a cheap smoke tester that uses mineral oil. I should be able to get somewhere with this, testing vacuum lines. If not, I am not going to waste any time on the stock 20v engine. Will report back on how that thing works. A proper smoke machine is about 1,200+ this one is $120 but having one of those around can be so convenient.
Im one step closer to just taking the rusty 4000, putting it on the lift and take the engine/drivetrain out to put in the clean 4K for now. Then figure out what to do with the body, It needs a good amount of work to it.
I was considering just lifting the body off of the engine/trans/subframe try and make it as easy as possible.
Well had some time this morning so I started prepping the clean 86 for a 20vt.
[img]
http://i1180.photobucket.com/albums/x41 ... scarfk.jpg[/img]
So theres where I't at now. Engine removed, need to remove the battery tray and some other useless bullshit. Clean the engine bay, get the stock CIS harness pulled.
Getting the battery tray out
Need to smooth over what's left and get it painted.
Then I will be getting rid of the unneeded wiring, and getting the engine bay clean.
stock 4K engine out.
Time to work on the "donor"
Old Exhaust out. With the Magnaflow muffler this sounded reallllly good. I think I am going to save it. Everything else will get redone with stainless and V-bands. I am not looking forward to doing the over-the-axle portion.
One thing that is sweet about this 4000 is that all the mounts are done on the subframe front and rear.
Really surprised with a car from Canada, I didn't have the use the torch barely at all. Had a few bolts stuck on the driveline and had to be really careful there. One broke, but other than that everything is coming apart real easy.
The challenge on dropping this engine out of the bottom is going to be the turbo. I got the downpipe off but getting the 4 bolts to remove the turbo is going to be really tough. Everything has been soaking in Kroil all night. Only other way i can picture it happening is if I can lift the car of the top and have the engine also move toward the drivers side, just enough for the turbo to clear the engine mount. Not sure if there's room.
Well I did get the engine out the bottom. Turbo did have to come off but it wasn't too hard to get once I removed the oil and coolant lines to it so I could get a wrench in there. Not too bad really. Everything came apart
Got the rear diff, suspension and subframe out too.
http://i1180.photobucket.com/albums/x41 ... gw5zhz.jpg
The next thing I need to figure out is my linkage issue. When I purchased the swapped 4000 with the 01E the linkage was hitting the trans tunnel. Very hard to see here. So I need to compare the stock to the 01E, do some reading and see what needs to happen.
Hard to see here.
I am at the point now where i am ready to transfer over the AAN/01E into the "clean 4000" commemorative edition body.
I have one thing left to sort out, the donor car already had the 01E swapped in- From driving it I could tell it had an issue with the shift linkage, turns out it was hitting the tunnel and rubbing against the back of the trans. I have read through some threads about how to swap in the
I need a little help deciphering what exactly I can do to remedy this issue but the problem is that I'm a little unsure of what parts were used to do the swap in the first place. Although they are rusty now the brackets look professionally made but I can't tell where they are from.
The easiest way I can think of to remedy the issue is to find a way to drop the back of the trans a little. I could use something smaller in place of the 30mm spacer under the drivers side bracket but that will effectively rotate the trans as well and that's not what I want to do I don't think.
Here is the trans. It is installed using no spacers for the axle and these "mystery" brackets as shown.
Clearance shot in the car:
brackets
Selector lever, 4A0 711 185 B (stock UrS car it looks like)
Good pics.
Up until now, I've only ever read about that interference. From what I remember, the solution was a BFH and making some room.
