correct.Josh wrote:Hi marc
I ripped out ABS on my coupe quattro and cut the wires and then realized that the rear diff wiring is within the ABS harness. If I install the v8 combo rear diff inside my coupe quattro diff I will not need the wiring and the vacuum setup anymore correct?
Thanks
Josh
Finished rebuilding the driveshaft, put everything back together, and drove the car in all 7 gears with the car on jack stands to verify everything. so far, so good. Should be able to put the car on the ground tomorrow.. but..
I think I may need custom tie rods. Just eye-balling the wheels straight I'm out of adjustment range on the passenger side tie rod :(
a_CQ
HT Motorsport
Cool,a4kquattro wrote:Finished rebuilding the driveshaft, put everything back together, and drove the car in all 7 gears with the car on jack stands to verify everything. so far, so good. Should be able to put the car on the ground tomorrow.. but..
Time to call rod end supply and online metals to get the parts you need for some nice chromoly ones with spherical rod ends
H
timmmy wrote:Cool,a4kquattro wrote:Finished rebuilding the driveshaft, put everything back together, and drove the car in all 7 gears with the car on jack stands to verify everything. so far, so good. Should be able to put the car on the ground tomorrow.. but..
H
H! Good to hear from you. Hope Australia is treating you well, I still haven't seen any pics of what you've been working on
haven't taken it to the shop yet, probably tomorrow. I'll most likely put it on the ground tonight.a_CQ wrote:Marc, any alignment updates?
HT Motorsport
RSCoupe
Thanks guys, I dig it too
I think I might give 034 a call, I know they make custom tie rod assemblies for a reasonable price so it would save me a bunch of time ordering the rod ends and making one myself. I'm thinking stock length - 3/8" should do.
heh, my car is not a good test mule, since I opted to cut the arms off the body. If I was to do the project over again (which, I wontAudilard wrote:Hey, Marc. When are you going to make and sell V8 engine mounts to fit the Coupe engine bay??? :-D
s2 on the way
90quattrocoupe
a_CQ
dspl1236
